Old 01-09-2021, 02:36 AM   #855
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by 86GP View Post
Hi Guys,
Has anyone had the issue where the oil temp reads and then resets to a negative -40 and only reads again if you reset app. I am using torque . I have tried 2 different readers . One did not work at all for oil temp only as everything else works and the second reads and then stops. Has anybody found a fix for this or should i just try another reader .
Awesome thread by the way .
Try disabling Faster Communication in Torque adapter settings and retry?
Compelica is online now   Reply With Quote
Old 01-10-2021, 11:49 PM   #856
86GP
Drives: 2013 Toyota 86
Will try that and see if it works ..
Sent from my SM-A705FN using Tapatalk
86GP is offline   Reply With Quote
Old 01-15-2021, 01:49 AM   #857
86GP
Hi Guys,
Managed to find a OBD reader that works perfectly .
I have had trouble using the ( Orange ) OBD Reader , which has the latest firmware . It would reset oil temps or not read at all even the fuel PID did not work .
I have a different reader VGate , its works perfectly with both the OIL and Fuel PIDS . This reader uses the older firmware 1.5 .
I hope this helps if anyone is having issues as to which OBD reader to use/try .
They both cost the same and are both bluetooth .
The Following User Says Thank You to 86GP For This Useful Post:
Bonburner (02-28-2021)
Old 01-15-2021, 01:57 AM   #858
86GP
I have this disabled as well currently . Not sure if that made a difference as i tried it on other readers and they still had issues . The Vgate works just fine with it disabled .
Old 02-28-2021, 10:56 PM   #859
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Hi Guys,
I just installed the VGate OBD2 scanner and my oil temp PID is finally working! Thanks for trying out this unit and sharing the info!
Old 03-09-2021, 04:50 PM   #860
map
map's Avatar
Drives: Toyota GT86
This seems to work on my GT86. (I use it directly via CAN bus, not Torque, but it should work the same.)
Fuel remaining in tank
OBD2 Mode and PID: 0x2129
Minimum Value: 0
Maximum Value: Should not exceed 100 (0x64) -> 50 liters
Scale factor: x1
Unit type: liter
Equation: A/2
OBD Header: 0x7C0
map is offline   Reply With Quote
Old 03-30-2021, 12:36 AM   #861
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Is there any way to get the Oil Pressure readout from the ECU with a PID?
https://www.ft86club.com/forums/show...2&postcount=14
Edit: nevermind, seems like its just an on/off switch :/
Old 05-08-2022, 08:54 AM   #862
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
If anybody is looking for the automatic transmission temperature PID, this one worked on my '17 86.
OBD2 Mode and PID: 0105
Minimum Value: 0
Maximum Value: 200
Scale factor: x1
Unit type: C
Equation: A-40
OBD Header: TCM
TheBoss77 is offline   Reply With Quote
Old 05-11-2022, 03:57 AM   #863
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by gcranston View Post
I found the following that looks promising, but I haven't figured it out yet:
From https://forum.autosportlabs.com/viewtopic.php?t=5319
The implementation for brake position adapted from this thread post seems to work well on Torque: https://www.ft86club.com/forums/show...4&postcount=15
PID: 2141
Min: 0
Max: 100
Scale Factor: x1
Type: %
Eqn: MIN(100 : (1.1 * MAX((A-10)))
Header: 7B0
EndlessAzure is offline   Reply With Quote
Old 05-11-2022, 04:49 AM   #864
EndlessAzure
Wheels for Brains
Minimum Value: 0
Scale factor: x1
Unit type: liter
Equation: A/2
OBD Header: 0x7C0
To inform folks that may be coming in new to this, this is the same as the original PID implementation stickied in Post #2 way back in 2013 of the same thread we are currently in: https://www.ft86club.com/forums/show...00&postcount=2
It comes down to what the interpretation of the PID is actually outputting. I think the consensus is that the PID value is % fuel level, but it really doesn't matter in the end because coincidentally when you divide by 2, it will also give the actual fuel tank capacity in liters.
Old 05-15-2022, 08:53 PM   #865
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
Minimum Value: 0
Maximum Value: 200
Scale factor: x1
Unit type: C
Equation: A-40
OBD Header: TCM
This did not work for me. 2017 86 auto. It shows a temperature, but I don't think it is correct. What temps do you show?
Daily86 is offline   Reply With Quote
Old 01-28-2023, 03:56 AM   #866
PikachuBRZ
waiting on yellow gas
PikachuBRZ's Avatar
Drives: 2017 BRZ Series.Yellow #247
Hey. I have the Elm 327 and Torque pro. Everything works great except for fuel pressure. I've tried to use all 3 options for fuel pressure and i get no data. I see that other people are able to monitor the HPFR without having to do anything. I've tried deleting and reinstalling torque pro but it hasn't helped. Is there any direction I can get towards what to try next or maybe the PID
PikachuBRZ is offline   Reply With Quote
Old 01-29-2023, 07:50 AM   #867
Compelica
Compelica's Avatar
Drives: 86 GT
Fuel pressure is not available as part of the generic OBD2 PIDs, but as the manufacturer-specific PIDs. Unfortunately I do not have the address either.
DIY stuff at Compelica Works
Old 02-14-2023, 12:49 AM   #868
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Does anyone know the vehicle speed pid and equation for a custom speed gauge? I want to add 10% to the speed to account for larger diamater tires.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
