Old 01-23-2023, 07:04 PM   #1
SpeBud07
Drives: 2013 FRS
Rubbin is racing’ — wheel rubbing issue
I am fighting a wheel rubbing issue in a 2013 FRS with the following mods:
TWS 18x9.5 et 45 with 255/35 Bridgestone Potenza Sports
Racecomp SS-1 coilovers
1.5 degrees of camber upfront
At full lock or close to it, I still rub a little at the top of the wheel well. Back it off to 1.0 degrees? 245/35 tires up front? I wanted a square setup, but since my wife works for Bridgestone that’s not a huge issue. The wheels are flush now, so much of a spacer might look dumb.
Thanks for any ideas!
SpeBud07 is offline   Reply With Quote
Old 01-23-2023, 07:33 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can raise your ride height a bit. About all you can do, narrower tire will help some, but you may still hit. My car rubs in the front and on top.
Old 01-23-2023, 07:46 PM   #3
SpeBud07
Drives: 2013 FRS
Do you mind sharing what your road to fender bottom is? I’m at 25.5 I think.
Old 01-23-2023, 08:49 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'll check when I get home in a couple hours. I believe I am lower than that. I also am on 245 17x9 +35 and sometimes a 235 17x9 +38 with an extra .5 degree of caster.
There are also steering limiters if it is only happening at close to full lock.
https://www.verus-engineering.com/sh...pra-1042#attr=
SpeBud07 (01-23-2023)
Old 01-23-2023, 10:22 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm at 24" 5/8 in the front.
Old 01-24-2023, 08:44 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Get skinnier tires and wheels. Only you give a shit ow the car looks.
A half inch isn't gonna do shit in terms of looks.
Old 01-24-2023, 10:39 AM   #7
SpeBud07
Drives: 2013 FRS
You'd think someone who lived in paradise would have a rosier disposition, but thanks for the note. Before I do that, I just want to make sure I've chased other avenues that are less expensive.
The Following User Says Thank You to SpeBud07 For This Useful Post:
x808drifter (01-26-2023)
Old 01-24-2023, 10:51 AM   #8
Vital
Drives: 2015 BRZ
Try the 245/35 tire or could even get a 3mm spacer
The Following User Says Thank You to Vital For This Useful Post:
SpeBud07 (01-24-2023)
Old 01-26-2023, 06:43 AM   #9
x808drifter
LMGTFY
You would. But you'd be mistaken.
The Following 4 Users Say Thank You to x808drifter For This Useful Post:
NoHaveMSG (01-26-2023), soundman98 (01-27-2023), Vital (01-26-2023), Wally86 (01-26-2023)
Old 01-27-2023, 09:54 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
i dunno, i can't even stand the word 'tourist'
x808drifter (01-29-2023)
Old 01-29-2023, 06:21 AM   #11
x808drifter
LMGTFY
ツーリスト?
Front right wheel is rubbing 86zn6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-06-2020 11:15 AM
Help with slight wheel rubbing. BEZO760 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-11-2019 11:37 AM
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 05:25 PM
Will this set up be a rubbing issue Astroboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-02-2014 09:15 PM
How to tell if front wheel is rubbing against strut? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-08-2013 10:54 AM
