Old 01-17-2023, 04:46 AM   #1
carson.frs
Drives: 2014 FRS
So I went over a curb
The other night I went over a curb in a parking garage which I really couldn’t see with my window tint, but besides the point, I didn’t notice till today the fender actually shifted it seems up and slightly outward from what I can tell.
I’m wondering if you guys recommend anything on fixing this or if I should just take it to a body shop and see what they can do. How much do you guys think it’ll cost to repair through a body shop? I’m gonna look more at the damage tomorrow but I think I’ll be more careful turning corners in parking garages now ��
carson.frs is offline   Reply With Quote
Old 01-17-2023, 07:47 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
The bottom mount for the fender is at the pinch weld. I bet if you crawl under your car, you'll see it's smashed up pretty good. Just my guess. Might be cheap but looking at the bow in the fender, probably not.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
Spuds (01-17-2023), x808drifter (01-18-2023)
Old 01-17-2023, 08:44 AM   #3
Grady
Grady's Avatar
Take it apart and look for bent things. From there we can tell how much to fix.
The Following 3 Users Say Thank You to Grady For This Useful Post:
soundman98 (01-18-2023), Wally86 (01-17-2023), x808drifter (01-18-2023)
Old 01-17-2023, 08:58 AM   #4
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Easy, there is a bracket on the fender that bolts to the body behind the door. See circle in pic, it's a 10mm bolt accessable in the door jam with the door open. Look there, and under the car directly below for bends. I'd bet both the bracket and the pinch weld are tweaked slightly.
Loosen the 10mm fender bracket bolt but don't remove it. If the pinch weld is bent adjust that first. You can use pliers, or a hammer to straighten the pinch weld. Use a towel, or block of wood to help protect the paint. Once the pinch weld is straight, then gently adjust the fender bracket to bring the fender back in line with the door. Once satisfied, retighten the bolt.
Probably will take about 30 minutes to fix...or a body shop will charge you $300-$500
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 12 Users Say Thank You to Opie For This Useful Post:
bcj (01-17-2023), Code Monkey (01-17-2023), dragoontwo (01-17-2023), FRSBRZGT86FAN (01-18-2023), jordan7831 (01-17-2023), norcalpb (01-17-2023), RToyo86 (01-19-2023), soundman98 (01-18-2023), Spuds (01-17-2023), Tcoat (01-17-2023), Wally86 (01-17-2023), x808drifter (01-18-2023)
Old 01-17-2023, 10:52 AM   #5
carson.frs
Drives: 2014 FRS
Ok yeah I saw that bracket yesterday so I’ll definitely mess with that and pinch weld. Definitely gonna do it myself cause I’m not paying a shop $500 to do a relatively easy job. Thanks for the feedback everyone!
The Following 3 Users Say Thank You to carson.frs For This Useful Post:
Opie (01-17-2023), Wally86 (01-17-2023), x808drifter (01-18-2023)
Old 01-17-2023, 07:12 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Don't bend or stress the fender itself too much. The paint might crack. You might want to loosen the top bolts while you are messing with the fender.
Yes, this has happened to me.
Also: "Build Thread"
The Following 3 Users Say Thank You to Spuds For This Useful Post:
soundman98 (01-18-2023), Wally86 (01-18-2023), x808drifter (01-18-2023)
Old 01-17-2023, 09:15 PM   #7
pope
has a funny hat
Drives: 2014 BRZ Limited
Incorrect. The obstructed visibility is the point. This time it was a curb, next time could be serious.
Get the fender fixed and lose the tint.
pope is offline   Reply With Quote
The Following 4 Users Say Thank You to pope For This Useful Post:
Jdmjunkie (01-17-2023), Spuds (01-18-2023), Wally86 (01-18-2023), x808drifter (01-18-2023)
Old 01-17-2023, 09:55 PM   #8
Spairo
Drives: 2013 FR-S 6 spd in Halo
Amen to this.
Sent from my SM-G990U2 using Tapatalk
Spairo is offline   Reply With Quote
The Following 3 Users Say Thank You to Spairo For This Useful Post:
FRSBRZGT86FAN (01-18-2023), Wally86 (01-18-2023), x808drifter (01-18-2023)
Old 01-17-2023, 10:26 PM   #9
Grady
Grady's Avatar
lose the tint.
But its cool and that kid should have not been in the intersection anyway.
The Following 2 Users Say Thank You to Grady For This Useful Post:
soundman98 (01-18-2023), x808drifter (01-18-2023)
Old 01-18-2023, 12:28 AM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
it only counts if someone screams
Old 01-18-2023, 08:08 AM   #11
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
That's what loud exhaust/sounds are for right?
Old 01-18-2023, 08:12 AM   #12
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
+1 on fixing your tint, your tint must not be legal if you couldn't see a simple curb or you need more awareness when slow speed driving.Either way you having to fix it will be enough of a deterrent to avoid this next time.
If you've got front windshield tint across the whole window you're already breaking the law and bringing unnecessary police attention to your vehicle.
Windshield: Non-reflective tint is allowed above the manufacturer's AS-1 line or top 4 inches.
Front Side windows: Must allow more than 35% of light in.
Back Side windows: Any darkness can be used. Rear Window: Any darkness can be used.
Source: https://www.tinting-laws.com/utah/
Copyright © Tinting-Laws.com
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Out of alignment after going over a curb:( SamtheKorean Issues | Warranty | Recalls / TSB 5 03-24-2019 05:43 PM
Went over curb Sedated Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-24-2017 02:37 PM
Curb hit FRSure Scion FR-S / Toyota 86 GT86 General Forum 16 03-31-2015 11:16 AM
Hit a curb :( aakash New England 0 10-14-2013 11:04 PM
Hit a curb Itssrayyxd Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-08-2013 11:09 PM
