Drives: Toyota
Curb hit
I have a little bit dilemma here, just want to get some answers from you guys.
> Was trying to get some food from McDonald, wheel hits curb (wasn't paying attention), now my steering wheel is off center. Is slightly tilted to the left. At highway speed (55 mph - 70 mph), the steering center is NOT shaking, nor is my car pulling to the side that much (very very little). What could be the problem? |
Drives: Whiteout FRS
Appears you may need an alignment but have the mechanic to verify no other parts are damaged.
| The Following User Says Thank You to shellslinger For This Useful Post: | Choco (03-30-2015) |
Drives: 2015 Scion FR-S Firestorm
Sounds like an alignment problem.
| The Following User Says Thank You to PBlack09 For This Useful Post: | Choco (03-30-2015) |
Drives: Toyota
Yeah. Definitely need an alignment! Just wanted to make sure that no other parts are broken. I hit the curb around.. 7-10mph?
http://mywethersfield.org/wp-content...ellow-curb.jpg Ran over one of these when turning my car. |
| The Following User Says Thank You to FRSure For This Useful Post: | Choco (03-30-2015) |
Drives: Raven 6 speed Manual FRS
Could have bent a tie rod. Have the shop check when you take it in for an alignment
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
| The Following User Says Thank You to AlanLGuy For This Useful Post: | Choco (03-30-2015) |
Car is totaled.
j/k At slow speed most likely nothing is broken, possibly a bent tierod, an alignment shop should help you out, just mention to them which corner you hit and maybe they can double check. |
| The Following User Says Thank You to swarb For This Useful Post: | Choco (03-30-2015) |
Drives: Toyota
Gonna give PTuning and MachV Motorsports a call tomorrow.
What are the chances that something else is broken? |
#8 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#10 | |
Drives: 2013 Subaru BRZ MT Limited
PTuning and MachV are both known as reputable shops around these parts so you're in good hands. Luckily a Tie Rod is a pretty cheap and easy fix relatively speaking! Should cost you a couple hundred dollars.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#11 | |
MJLONIR Program Member
Drives: 2014 Scion FR-S
Ran over this going almost 35mph (slowed down for it). Saw a car backing up in the distance thinking, "What is he do--SHHHEEEEE---!" These are the problems when its dark, 0430, your friend booked the only flight in the morning, and he asked for a ride to the airport. Long story short, I pulled off, made sure nothing was cracked/broken (amazes me nothing was), and verified the alignment was not compromised. Just had an inspection and nothing was reported wrong.
ドラゴンに乗る
Instagram: Komodo_Actual My car build: http://www.ft86club.com/forums/showthread.php?t=81094 |
#12 | |
Drives: In between cars... 2018 Ninja 1000
Seriously though, what is that you hit? Railroad tracks? |
| The Following User Says Thank You to driftguy For This Useful Post: | Tcoat (03-30-2015) |
#13 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | bigred18 (03-31-2015) |
| I dun goofed into a curb | sittinSideways | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-30-2015 11:00 PM |
| Curb rash what should i do? | Rocket.BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 06-02-2014 07:38 PM |
| Spun out and hit a curb... | JohnAyySays | Issues | Warranty | Recalls / TSB | 54 | 12-09-2013 10:59 AM |
| Hit a curb :( | aakash | New England | 0 | 10-14-2013 10:04 PM |
| Hit a curb | Itssrayyxd | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 02-08-2013 10:09 PM |
