Any ideas why both of my cats failed?
2018 BRZ, MT, ~36k miles, JDL UEL catted header, OFT stage 2 tune, 93 octane gas, K&N drop-in filter
So a few weeks ago my car started exhibiting a huge loss of power, and also had an odd drone in the exhaust note. It felt like anything over ~20% throttle was ineffective. On the highway I'd lose speed when going uphill, and couldn't regain it until going back downhill. No CELs. I cleaned the MAF sensor and PCV valve, and also found that the clamp connecting the intake tube to the air box just after the MAF was loose and tightened it. I measured the resistance between the various wires on the two O2 sensors, and found 2.5 ohms between the two black wires on the upstream sensor, and 5.8 ohms between the two black wires on the downstream sensor, and no connection between any other combination. No changes in power yet. I also took a look at a spark plug (photos attached). I chose plug #3 because several months ago I had a #3 misfire CEL pop up out of the blue while on the highway, but after clearing it everything seemed fine. The tip looks a little black, but it didn't wipe off on my finger like if it were soot. I went ahead and got some replacement plugs but haven't installed them yet. Next I found an exhaust leak at the header, and ordered all new gaskets. When I installed them I took a look inside the header, and found that it was now catless. So I also removed the front pipe, and saw that it too was now catless. The remnants of both cats were crammed inside the front pipe where the diameter gets smaller, mostly blocking the exhaust. Removing all of that (and loading the stage 2+ tune) fixed the power issue, but now my big concern is finding and fixing the original issue before replacing at least the second cat. From what I've read, it sounds like an excessively rich fuel mix or unburnt fuel reaching the cats is what would cause them to fail, but I'm still not clear on why or if that's my case. Here's a log from back when the exhaust was clogged: https://datazap.me/u/kambroso/log-16...0?log=0&data=1 And here's a log from the other day: https://datazap.me/u/kambroso/log-16...7?log=0&data=1 Any ideas of what could have caused my cats to fail, and whether I still have that issue? Let me know if I didn't log the proper items to diagnose this issue. If that spark plug does look bad to you guys then I'll go ahead and get those changed out, and let me know what else I should check. Thanks in advance! |
#2 |
Drives: Subaru BRZ
The cats in JDL products are low quality, I had mine rattling in the front pipe after one track weekend...
#3 |
Drives: 2013 frs base
I have a AFE catted header and the cat went bad after throwing a rocker arm. I had to drive 30 miles to get home. I was told running rich will kill a cat. I knocked it out. I replaced the secondary cat with a Nameless 2.5" catted front pipe with a Helmholtz resonator. Been living happily ever after.
#4 |
Human
Drives: 2015 BRZ Black
JDL cats are known for being low quality and dissolving. Combine with a stage 2 tune that is designed for catless headers, and you probably killed them.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#5 |
Drives: brz 2017 hksv2
log doesn t tell us much about your fueling since it s all closed loop
the trims in those anyway is acceptable You should log a full throttle pull to redline and maybe modify the tune to suit your car better if it that will be the case |
| The Following User Says Thank You to tomm.brz For This Useful Post: | kambroso (01-16-2023) |
#6 |
The OFT Stage 2 hardware requirements call for a catted header, but you're saying it's still bad for that cat? I've also run the E85 tune during track seasons, which says catted or catless header, perhaps that tune isn't great for the cat either?
I'll post a new log as soon as I can. |
| The Following User Says Thank You to kambroso For This Useful Post: | Wally86 (01-17-2023) |
#7 | |
Drives: 2020 GMC Canyon Denali Diesel
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#8 |
Nobody asked.
Pop tune?
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#9 |
I'm not sure what that means. A tune that makes popping sounds in the exhaust? Does that work by letting unburnt gas into the exhaust? If so I image that would ruin the cats quickly. The tunes I use are the regular ones downloaded directly from the OFT site.
| The Following 2 Users Say Thank You to kambroso For This Useful Post: | Tcoat (01-16-2023), x808drifter (01-17-2023) |
#10 | |
Well the leaks are fixed, and tomm.brz has offered to help customize my tune, so hopefully I'll be in better shape soon. |
| The Following 4 Users Say Thank You to kambroso For This Useful Post: |
#11 |
Yes they are a horrid tune that some use to sound "cool". They will blow cats away. You would have know if you had them!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | kambroso (01-16-2023), x808drifter (01-17-2023) |
#12 |
Drives: frs
Don't worry, worst case scenario is: de-cat the header or maybe work with Jesse at JDL for a replacement if you are the original owner.
| The Following 4 Users Say Thank You to Teseo For This Useful Post: |
#13 | |
Here's a 2000 rpm to redline WOT pull in 3rd: https://datazap.me/u/kambroso/log-16...zoom=2990-3140 |
#14 |
tune is much improveable
but i don t think it killed the catalyzer, i think was because of unluck/bad quality |
| Passing emissions in CO cats or no cats? | xZAMx | Rocky Mountains / Great Plains | 4 | 05-25-2021 12:16 AM |
| Cats | suzyj | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 01-31-2019 02:13 PM |
| Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 06:27 PM |
| No cats | tzbang | Engine, Exhaust, Transmission | 8 | 11-30-2015 04:37 PM |
| OEM cats only ? | 350matt | Engine, Exhaust, Transmission | 7 | 11-26-2013 07:30 PM |
