Old 01-10-2023, 10:28 AM   #1
TwinFTW
Drives: 17 BRZ w/PP & 08 STI
Pedders offset camber/caster strut mount - sheared bolt
Just an FYI to those of you using pedders top mounts.
I had one of the 3 nuts back off to the point that there was enough play to create a feint clunk over a year ago, so I've been re-torqing the nuts to 17 ft/lb on oil changes just for piece of mind.
2nd oil change retourqing - and one of the bolts sheared.
I love them otherwise, so I ordered another but figured I would post up to see if others have heard of this?
TwinFTW is offline   Reply With Quote
Old 01-10-2023, 12:21 PM   #2
norcalpb
norcalpb's Avatar
Are you using the oem nuts? Unfortunate to hear, but you may have just gotten a bad batch.
I’m on my 2nd set and all is well.
Old 01-10-2023, 05:25 PM   #3
TwinFTW
Yup, OEM nuts. Just ordered 6 new OEM nuts as well to use when the top hat arrives.
Old 01-10-2023, 08:34 PM   #4
norcalpb
norcalpb's Avatar
I assume you let Pedders know and they are taking care of you?
Old 01-11-2023, 02:35 AM   #5
Little dab of Loctite blue will fix that right up.
MrSkubi (01-11-2023), MyHybridBurnsGasAndTires (01-17-2023), RToyo86 (01-11-2023)
Old 01-12-2023, 08:34 PM   #6
Joon525
Joon525's Avatar
Drives: 2016 BRZ
You can also just buy stronger/newer studs instead of buying a whole new mount.
Example
Another one
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
TwinFTW (01-30-2023), Ultramaroon (01-13-2023)
>>SOLD<< RACESENG Adjustable FRONT CAMBER + CASTER Strut Mount Plates Lightened Brakes, Suspension, Chassis 7 09-16-2019 03:09 PM
Pedders offset front strut mount? Any knowledge? 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-20-2019 03:20 PM
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 04:35 PM
Those Who Have Cusco Strut Bar, Which Camber Top Mount Do You Run? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-03-2013 04:01 PM
