Old 09-03-2013, 04:01 PM   #1
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Question Those Who Have Cusco Strut Bar, Which Camber Top Mount Do You Run?
I would like to order a set of Front camber Mount for my stock shock with lowing springs on it (Not Coilovers).
I have a Cusco tower bar, and it may touch mounts like HVT and ground control(as image shows). --- I am not sure. I just think these mounts are higher than stock mounts.
Whiteline mounts will fit perfectly, but they have some popping issues.
So is there any other camber mounts recommended? or any mounts that you are running fine with Cusco strut bar?
Someone recommended Vorshlag, but I was not able to find a Vorshlag mount that work with stock shock. All of them that I found were designed for Coilovers. Can anyone give me a link?
Thanks!
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
Cusco Vertical Mount Air/Oil Seperator Supermassive Engine, Exhaust, Transmission 23 04-29-2015 06:45 PM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
GT Spec Strut Tower Bars / Front - Rear - 3 Mount / Available in Stock @ Import DPS!! rickspecd Brakes, Suspension, Chassis 3 07-12-2013 11:49 AM
New cusco transmission mount! Silverdub Engine, Exhaust, Transmission 5 07-11-2012 08:50 AM
