Old 12-13-2022, 11:39 PM   #57
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
This isn't your jeep. There's no gap. The TOB stays in contact with the fingers. Don't argue. Go look and learn. Think about how this system manages to to do this without need for adjustment as the clutch wears.
The self adjuster is the spring I speak of in the slave cylinder. It also tells why the TOBs fail like rotary seals. Now keep trying to defend how that was a shit installation and not the Verus fork where this all started for me? Please, you have so much more berating to go.
jeepmor is offline   Reply With Quote
Old 12-14-2022, 01:24 AM   #58
Wish you all the best.
Old 12-14-2022, 01:58 PM   #59
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It honestly sounds like it could be a missalgined clutch disc too. I bought the OS Giken tool just to avoid some of the clutch install issues that can be causes by the plastic installation tool.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
CSG Mike (12-14-2022), Jdmjunkie (12-14-2022), soundman98 (12-14-2022), Wally86 (12-22-2022), x808drifter (12-16-2022)
Old 12-21-2022, 09:40 PM   #60
jeepmor
Please keep elaborating as I don't follow how this won't self correct.
Old 12-29-2022, 04:02 PM   #61
MX-5RACER
Drives: 1999 Miata
This could also have been clutch chatter from oil being left on the pressure plate or flywheel during installation. I have also seen cases where someone lubes up the transmission input shaft a little too much and flings grease onto the clutch.
The oil on the contact surfaces causes slip/grip and hot spots and can lead to chatter.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 12-30-2022, 09:04 AM   #62
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I know that this subject has been discussed ad nauseum is other posts, but I still don't understand the logic behind using the Gilkin tool vs a plastic one.
If the clutch disc is successfully "aligned" to allow installation of the transmission, what other "alignment" is relevant? I do not feel that I can move forward into the new year without understanding this concept.
The Following User Says Thank You to blsfrs For This Useful Post:
Decep (12-30-2022)
Old 12-30-2022, 11:19 AM   #63
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The idea behind it is to prevent input shaft binding on the disc and pilot bearing on install. Being slip fit there is obviously some tolerance there, but items like the pilot bearing have a surprising amount of play in them from the inner to the outer race to allow for expansion. Using a higher precision alignment tool helps minimize the issues. I know with the plastic tool the exedy kit comes with, mine was visibly off. I usually have to hold the tool up while tightening or it sags and causes it to be off.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (12-30-2022), Ultramaroon (12-30-2022), x808drifter (01-02-2023)
Old 12-30-2022, 05:40 PM   #64
blsfrs
blsfrs's Avatar
I hear what you are "saying", but if the transmission will mate up, all that goes out the window. There is play in the pilot bearing and in the input shaft so as @jeepmor said, it is self-correcting. What am I missing?
Old 12-30-2022, 06:28 PM   #65
I've wondered about this many times and the only potential issue that I can picture would be deformation of the friction disc about the hub as the input shaft is loaded to mate with the pilot. That seems like a stretch but the end result would be a dragging clutch.
blsfrs (12-31-2022)
Old 12-30-2022, 07:07 PM   #66
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it goes in fine yeah, I would say it is fine. If it goes in a little tough then potentially it could be loaded a bit more on one side, disc and/or pilot bearing. The bearing surprisingly has bit of axial play in it between inner/outer races, not just fit between shaft and inner race. I tried to take video on my phone by it doesn't translate well. That's the way my brain sees it anyway.
blsfrs (12-31-2022)
Old 12-30-2022, 07:22 PM   #67
I don't think you're the target market. If my hypothesis holds true, it would take a mechanical sociopath to willingly torque it enough to get it started. The damage takes place before it's even rammed home.
blsfrs (12-31-2022), NoHaveMSG (12-30-2022)
Old 12-30-2022, 07:36 PM   #68
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, new clutch didn't come with an alignment tool and I broke my other so I figured why not
blsfrs (12-31-2022), Ultramaroon (12-30-2022), x808drifter (01-02-2023)
Old 12-30-2022, 09:34 PM   #69
Oh, it's nice. The plastic ones suck. I'm thinking input shaft from a junk transmission.
Old 12-31-2022, 08:52 AM   #70
blsfrs
blsfrs's Avatar
Back in the good old days, Chevys used the same input shaft on everything they made. We had an input shaft alignment tool that worked on anything GM from the 1940's thru the 1980's. Even the bolt pattern on the transmissions was the same.
I would say that 98% of the time, the plastic tool will work just fine, if you are careful.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (12-31-2022), Ultramaroon (12-31-2022)
Bucking on throttle application? Mr_Eyo Software Tuning 57 11-21-2018 02:45 AM
E85 OFT tune Bucking/surging Vmax911 Software Tuning 5 07-30-2017 03:27 AM
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 08:10 PM
2-3K RPM hesitation/bucking - logged 86fun Software Tuning 5 01-29-2016 08:58 AM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 02:08 AM
