#43 | |
Drives: Crapcan
#44 | |
Once the ECU adjusts to tabs, switching back throws the measured discrepancy out too far for the servo system to pass the initialization test. That's when the zero value is reported, the system gives up, and it throws the p001(6-9) codes.
#45 |
Drives: 2013 FRS
it was running pretty good I think. On a Mustang Dyno was 260hp and 217tq with 91 octane at 5lbs of boost. We will see how it does with a good build and lower compression in a week or 2 after some break in miles.
#46 |
Rust bucket enthusiast
You are going to lose a good amount of power if you lower compression, please keep that in mind.
#47 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (12-19-2022) |
#48 |
Drives: 2013 FRS
| The Following User Says Thank You to jonho For This Useful Post: | DarkPira7e (12-19-2022) |
#49 | |
edit:wait, nvm. new ecu duh
#50 |
I'm equally surprised. I knew the cam sensors were the same but still... wow.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jonho (12-20-2022) |
#51 |
Drives: 2013 FRS
#52 |
The old ECU triggers on the negative-going part of the waveform. The signal from the tabbed reluctor has a negative-going part but it's at the end of the pulse, not the beginning.
#53 |
Drives: 2013 FRS
Well so far so good have 600 miles on it issue free! Thanks for the help understanding what was going on with it!
| The Following 3 Users Say Thank You to jonho For This Useful Post: |
| Timing Chain cover revisions / changes 2013-2020 | FrickingReallySlow | Engine, Exhaust, Transmission | 0 | 09-21-2021 05:10 PM |
| Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) | MJones_RB | Issues | Warranty | Recalls / TSB | 9 | 08-22-2019 04:00 PM |
| Cam position - timing issue. | cab33 | Engine, Exhaust, Transmission | 3 | 07-01-2018 11:52 AM |
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-10-2016 11:25 PM |
| FT86Cup Round 4: WSIR 6/16/2013. Only $100 w/ timing! | CSG Mike | Tracking / Autocross / HPDE / Drifting | 47 | 06-24-2013 05:23 PM |
