Old 12-19-2022, 01:57 PM   #43
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by jonho View Post
Its odd that it ran fan the whole time we had it on the old ECU and tabbed gears then when we rebuild it runs but shows 18* advanced on intake cams. My theory is someone redid timing before we owned it did a replacement ECU tabbed gears and had the intake cams off a tooth then on startup thats how it learned it??
I'm surprised it ran like that at all without throwing a code.
Old 12-19-2022, 02:51 PM   #44
those are views of first-gen and second-gen sensor outputs. The polarity reversal is solely a function of switching from valleys to hills. I wonder if the ecu can learn to compensate for the change in one direction. ...one way trip for the initial position values. I think that's what they're called.
I don't know if I'm writing in Sanskrit but this is almost certainly what happened. Old ECU can read output of tabs and adjusts IPV table accordingly. I'll guess that it ran like shit but would have to work out the numbers to verify.
Once the ECU adjusts to tabs, switching back throws the measured discrepancy out too far for the servo system to pass the initialization test. That's when the zero value is reported, the system gives up, and it throws the p001(6-9) codes.
Old 12-19-2022, 03:52 PM   #45
jonho
Drives: 2013 FRS
it was running pretty good I think. On a Mustang Dyno was 260hp and 217tq with 91 octane at 5lbs of boost. We will see how it does with a good build and lower compression in a week or 2 after some break in miles.
jonho is offline   Reply With Quote
Old 12-19-2022, 04:23 PM   #46
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You are going to lose a good amount of power if you lower compression, please keep that in mind.
Old 12-19-2022, 04:50 PM   #47
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think you are right, I am just still surprised it can learn it. I thought the difference in cam positions sensors and gears was one of the issues swapping a facelift engine into pre-facelift along with the different crank position sensor and reluctor wheel.
Old 12-19-2022, 05:09 PM   #48
jonho
Drives: 2013 FRS
Yes if we kept it the same but doing other upgrades and a 3port pretty similar build to yours actually and will be on flex fuel.
Old 12-19-2022, 07:03 PM   #49
If that valve timing isn't stock, be careful. May have been tuned for peak performance with offset angles, and not noticing the deviation from typical values. Not sure. Just things that I'd sweat.
edit:wait, nvm. new ecu duh
Old 12-19-2022, 07:11 PM   #50
I'm equally surprised. I knew the cam sensors were the same but still... wow.
Old 12-20-2022, 06:27 PM   #51
jonho
Drives: 2013 FRS
so really it would just learn if the change was 5v or 0v a dip or a peak. I would see how it could learn that everything else being the same.
Old 12-21-2022, 01:37 AM   #52
The old ECU triggers on the negative-going part of the waveform. The signal from the tabbed reluctor has a negative-going part but it's at the end of the pulse, not the beginning.
Old 12-22-2022, 10:59 AM   #53
jonho
Drives: 2013 FRS
Well so far so good have 600 miles on it issue free! Thanks for the help understanding what was going on with it!
Timing Chain cover revisions / changes 2013-2020 FrickingReallySlow Engine, Exhaust, Transmission 0 09-21-2021 05:10 PM
Issue With Inlet Camshaft Timing Distributor (reference from Reddit post) MJones_RB Issues | Warranty | Recalls / TSB 9 08-22-2019 04:00 PM
Cam position - timing issue. cab33 Engine, Exhaust, Transmission 3 07-01-2018 11:52 AM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
FT86Cup Round 4: WSIR 6/16/2013. Only $100 w/ timing! CSG Mike Tracking / Autocross / HPDE / Drifting 47 06-24-2013 05:23 PM
