Old 06-30-2018, 02:43 AM   #1
cab33
Drives: Fast
Cam position - timing issue.
My 2013 FRS has a cam / crank position code.
The mechanic/shop I have it at is very familiar with the cars.
He has done the cam position sensor shims.
He replaced both timing chains.
Neither fixed the problem.
Any suggestions?
cab33 is offline   Reply With Quote
Old 06-30-2018, 02:54 AM   #2
humfrz
Any suggestions?
What code is your engine giving you?
What power mods, if any, do you have?
You may wish to review this thread.
http://www.ft86club.com/forums/showthread.php?t=123459
humfrz
Old 06-30-2018, 06:54 PM   #3
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I had code p0013 and some others camshaft actuator position sensor.. car was shaking.. turned out to be faulty wiring... Check your wires for burns
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 07-01-2018, 11:52 AM   #4
sumgai
sumgai's Avatar
Drives: 2013 FR-S, 18 Colorado ZR2
I think I had a similar problem, replacing the ECU ended up fixing it. Check out this thread
http://www.ft86club.com/forums/showthread.php?t=15577
sumgai is offline   Reply With Quote
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 08:49 PM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
What position do you sit in FR-S/BRZ??? cry7670 Scion FR-S / Toyota 86 GT86 General Forum 25 05-09-2015 12:08 PM
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 07:24 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 01:28 PM
