| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#29 | |
Less rotor mass = less sink = larger temp swings. Always balance the brake system "upgrade" with needs and use case. |
#30 |
Drives: 2022 GR86
The aftermarket calipers that don't look like stock are typically also made out aluminum.
Follow the build thread for my GR86!
| The Following User Says Thank You to timurrrr For This Useful Post: | DocWalt (12-09-2022) |
#31 |
Drives: 17 Asphalt 86
Seems reasonable given they're optimized for this platform. Just hard pill to swallow with Canadian conversation which would put it closer to $1200.
#32 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | DocWalt (12-12-2022) |
#33 |
Drives: 2022 Toyota GR86 Premium 6MT
Funny, I have these bookmarked in my car parts folder for when I kill the stock pads lol. Heard great things about them, hopefully the performance lives up to the pricetag.
#34 |
Drives: 22 BRZ limited
#35 | |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
#36 | |
That said, I personally wouldn't run a street pad with a race caliper, but it may uniquely fit Pat's scenario. |
#37 | ||
#38 |
Drives: 2023 BRZ
Mike and I have had many discussions about my "compromise" car. I make known sacrifices in some areas to better fit my priorities in others. My choice is an uncommon one. My car gets used in a much wider variety of scenarios than the vast majority of BRZs.
#39 |
#40 |
Drives: '23 BRZ Limited
Any particular reason why? I'm just curious.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#41 |
Drives: 2023 BRZ
There are a few factors. I only want to have one car. But I want to use it to ski most weeks during the 1/3rd of the year. I often ski above 12,000 feet, so it's cold where I go. I drive the car on 2,000 mile road trips annually. I get in 20-30 track days annually. The car will wear snow tires and 200TW tires. The car won't see dramatic power increases due to forced induction.
All of this adds up to a very diverse use case. Any time one sets up a car for this there will be compromises. A specialty tool will always have the potential to outperform a more generic tool. So why use AP 9660s with CPs on my car? The heat capacity and cooling capability of the 9660 caliper with 355 mm rotors will keep the pads within their intended operating heat range. I was surprised to hear this, too. But JRitt thinks DS2500s would also get the job done. So while I'm skeptical about using a single pad compound for winter mountain driving and tracking with 200 TW tires, there are people that know much more about brakes than I do that seem to think this is a viable option given my priorities. Time will tell.
| The Following User Says Thank You to Pat For This Useful Post: | Jdmjunkie (12-10-2022) |
#42 | |
Drives: 2022 GR86
| Safe oil temps for daily driving and spirited driving off the track? | MilkyWitness | Engine, Exhaust, Transmission | 15 | 06-12-2019 08:21 AM |
| Video Journal? Performance driving progression | Jordanwolf | Member's Car Journals | 3 | 05-07-2019 01:33 PM |
| Daily Driving/Spirited Driving Brakes | VABeachBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-12-2017 04:11 PM |
| Rev Works Braking Upgrade Sale! | Rev Works | Brakes, Suspension, Chassis | 4 | 11-04-2015 09:47 AM |
| Daily driven with upgrade specs | Tycocentrouz | Member's Car Journals | 0 | 09-16-2014 11:13 AM |
