Old 12-06-2022, 07:18 PM   #29
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I think it'd have to be pretty bad. I'm skeptical too. They switched to a forged design but I don't see any finish machining in the pics.
There are no finishing/machine marks, zero, it was 100% cast. You can now see wear on the ball pivots and where the fork touches the TOB. And again, mine exhibited the problem from day one.
jeepmor is offline   Reply With Quote
Old 12-06-2022, 07:23 PM   #30
Do you still have the fork? I'd like to examine it if you are game.
Old 12-06-2022, 07:55 PM   #31
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's forged 100%, not cast. I have one sitting on my desk waiting for install. You can't just base it solely off the surface finish at first glance. Looking at it you can see the parting line from the die and you can see the draft for the dies in the edges. Cast parts usually come out cleaner to be honest. Ever see a forged rod that doesn't have surface finish machining? This is an eagle forged rod for a SBC.
Ultramaroon (12-06-2022)
Old 12-06-2022, 09:59 PM   #32
jeepmor
Forged, okay I see it now. How do I share pics? It does have two holes and some pockets milled at fork end for clip retention. The pivot clip is milled open. I do see what looks like a mold part line, or rather a forge line like a high pressure stamping.
The interesting bit is the wear, the pivot pocket has significant wear you can feel with your fingernail like a button from the drilled open top of the pivot ball. I'd guess 10-20 thousandths of an inch.
Old 12-06-2022, 10:16 PM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Like this ? This is a used fork I picked up.
jeepmor (12-09-2022)
Old 12-06-2022, 10:24 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
For shits n giggles I ran back and threw it in my hardness tester. Granted I didn't sand in a smooth spot and level it but it's pretty hard. I would say it's in the range of 34-38 hrc. A decent high carbon knife or a truck leaf spring is about 42 hrc for reference. I would shoot Verus a message. They are pretty responsive and care about the product they put out.
Wally86 (12-07-2022)
Old 12-06-2022, 10:29 PM   #35
are the fork tines symmetrical about the center plane?
Old 12-06-2022, 10:41 PM   #36
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In my 4 handed attempt at taking a picture of it, it's close but it looks like it's off a smidge. Hard to tell without another set of hands. Could have it off the peak a bit on one side. I didn't check the lengths.
Old 12-06-2022, 10:46 PM   #37
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Use the right measure.
NoHaveMSG (12-06-2022), Ultramaroon (12-06-2022)
Old 12-06-2022, 11:09 PM   #38
It's ok. I would set up a jig with a camera and plug that into inkscape.
Old 12-06-2022, 11:10 PM   #39
Right?! JFC, what a cruel joke!
Old 12-06-2022, 11:17 PM   #40
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Would be nice if I could just scan it and port it into solid works. Even nicer if I could scan the stock one too and have SW merge the two and match points.....but I sold my scanner.
Old 12-06-2022, 11:26 PM   #41
I killed my scanner by leaving it on a shelf for too long.
Old 12-06-2022, 11:28 PM   #42
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
jeepmor (12-09-2022), Ultramaroon (12-06-2022)
Bucking on throttle application? Mr_Eyo Software Tuning 57 11-21-2018 02:45 AM
E85 OFT tune Bucking/surging Vmax911 Software Tuning 5 07-30-2017 03:27 AM
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 08:10 PM
2-3K RPM hesitation/bucking - logged 86fun Software Tuning 5 01-29-2016 08:58 AM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 02:08 AM
