Old 12-05-2022, 12:25 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by RedReplicant View Post
That is an extremely weird source for something like this...
I was thinking the same.
Old 12-05-2022, 02:32 PM   #16
Consider an imaginary plane intersecting the top and main pivots along the longitudinal axis. That plane must bisect the line drawn between the contact points on the tines of the fork.
Is it really the issue? I don't know, but I've considered it.
jeepmor (12-06-2022), NoHaveMSG (12-05-2022)
Old 12-05-2022, 09:07 PM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I have a Verus fork I am about to put in...
Also: "Build Thread"
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
Wally86 (12-06-2022)
Old 12-05-2022, 09:55 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
but how many verus forks have been sold, and this is the first related issue to surface here since they developed it in early 2014?
The Following 6 Users Say Thank You to soundman98 For This Useful Post:
DarkPira7e (12-05-2022), Jdmjunkie (12-06-2022), PulsarBeeerz (12-12-2022), Spuds (12-05-2022), Ultramaroon (12-05-2022), Wally86 (12-06-2022)
Old 12-05-2022, 10:19 PM   #19
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I wouldn't hesitate. I didn't want to say anything, but this sounds more like a shop who makes mistakes is taking an easy scapegoat. I've heard ' oh yeah, we've seen failures after installing those" when it's really just bad installation practices.
I have one installed, many people have them. Go ahead and Google " Verus clutch fork issue" and watch as nothing pops up..
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
Jdmjunkie (12-06-2022), Spuds (12-05-2022), Wally86 (12-06-2022), x808drifter (12-06-2022)
Old 12-05-2022, 11:19 PM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have a Verus fork and pivot and south bend stage 2. Works perfectly for about 4 years now.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Old 12-05-2022, 11:22 PM   #21
Spuds
The Dictater
Spuds's Avatar
Was still planning on installing it lol. All valid points though. I've never heard of anyone else having issues either.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
DarkPira7e (12-05-2022), Jdmjunkie (12-06-2022), Wally86 (12-06-2022)
Old 12-06-2022, 12:21 AM   #22
I think it'd have to be pretty bad. I'm skeptical too. They switched to a forged design but I don't see any finish machining in the pics.
NoHaveMSG (12-06-2022), Wally86 (12-06-2022)
Old 12-06-2022, 01:20 AM   #23
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Originally Posted by Wally86 View Post
What in the tolerance was sloppy?
Per the mechanic, the clutch wouldn't completely disengage which was my difficult shifting issue.
So the pivot points of contact were less than needed. This could be a pivot pocket too deep or the seesaw contact points not being far enough from the pivots in the parallel plane. This also hints to me my throwout bearing never took any time off.
I agree, it has baffled me, but it is now a night and day difference. I could put it in reverse on cold days and the drivetrain would shake because the clutch was not fully disengaged. Please tell me how this could be installed improperly, there is no room for adjustment on this assembly. And the shop that fixed it said they've seen several as they are a subi specific legit dyno speed shop. It was not the shop that installed it.
I agree, but how could this part not be installed properly. Blame it all on a worn pivot or such. All other parts were brand spanking new. Wear marks on everything were normal, the fork didn't slip off the the TOB at all.
Bottom line, I replaced that part back to OEM and I'm good. You can defend Verus and doubt me all you want. The mechanic said the previous install was sound, and had seen these before. Call Surgeline yourself and ask them to elaborate.
jeepmor is offline   Reply With Quote
Old 12-06-2022, 04:58 AM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder if pedal travel was checked/readjusted after changing out clutch fork.
Spuds (12-06-2022), Wally86 (12-06-2022)
Old 12-06-2022, 08:21 AM   #25
Spuds
The Dictater
Spuds's Avatar
This would be my guess. The aftermarket clutch might have some increased thickness somewhere as well. Also, the oem fork might be flexing a bit more than the forged one. An extra mm could make up the difference.
Old 12-06-2022, 09:52 AM   #26
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
DarkPira7e (12-06-2022), Jdmjunkie (12-06-2022), Ultramaroon (12-06-2022)
Old 12-06-2022, 10:36 AM   #27
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by x808drifter View Post
#4...
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 12-06-2022, 07:08 PM   #28
jeepmor
From post #4, one of mine.
"Feels like wheel hop on a leaf spring suspension. It is clutch chatter of some sort, just expected it to wear in by now and go away. The feeling from the driver's seat is that the tailshaft of the trans is moving, or the rear suspension connection to the unibody is bucking to and fro its range of motion.
It is a 350 ft-lb clutch."
I really thought it was just the beefier clutch causing the chattering due to the extra torque impulse exceeding the stock bushings design and the stock bushing were now too soft. Namely the rear diff bushings that connect the subframe to the back of the differential.
Also, I have no axe to grind with Verus, I was just told by the shop they've experienced this before with this particular part. They had no negative feedback on other Verus parts, just this one.
Knowing how this clutch goes together, there isn't any adjustment to the fork engagement. If like my old CJ7, I have an adjustable threaded section in my linkage to set the clutch fork hold off clearance so it isn't touching the TOB and spinning it while running. I have no adjustment on the throw distance of the jeep system either, the bellcrank (linkage) assembly controls that, and is fixed.
Subarus don't even have that, and the first shop tried to fix it when I complained about it. All I found on my own was that I can adjust the pedal height with adjustable linkage in the cab at the pedals, but this is not an adjustment of throw distance, or even the clearance setting to keep the fork off the TOB when in gear and clutch engaged, there isn't any adjustment on these like that. But it is nice to lower the pedal a bit so you don't have to lift your heel. If you do this, be careful, it does not take much adjustment to have the clutch engage while the pedal is barely off the floor.
I tried some of this setting both high and low to see if it would change the condition, it did not.
I share this only because I finally got this issue fixed and found the root cause and thought it relevant in this forum.
Bucking on throttle application? Mr_Eyo Software Tuning 57 11-21-2018 02:45 AM
E85 OFT tune Bucking/surging Vmax911 Software Tuning 5 07-30-2017 03:27 AM
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 08:10 PM
2-3K RPM hesitation/bucking - logged 86fun Software Tuning 5 01-29-2016 08:58 AM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 02:08 AM
