Old 11-23-2022, 02:55 AM   #1
Goodcake
Drives: None
Angry Please Help! Trunk Lock Out Problem
Need help bad! I activated the Trunk Lock out feature so only the key will open it and locked the key in the trunk.... I know total failure.. is there anything i can do? Also the spare key seems to just be for valet and wont open the trunk either....
Goodcake is offline   Reply With Quote
Old 11-23-2022, 06:29 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Undo the latches for the rear seat and crawl back there.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
Wally86 (11-23-2022), whataboutbob (11-24-2022), x808drifter (11-23-2022)
Old 11-23-2022, 11:14 AM   #3
AJ32162
Drives: 2019 BRZ with Performance Package
Try this:
AJ32162 is offline   Reply With Quote
The Following User Says Thank You to AJ32162 For This Useful Post:
DarkPira7e (11-23-2022)
Old 11-23-2022, 11:23 AM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Car came with 2 regular keys and 1 valet key.
Old 11-23-2022, 11:24 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I accidentally locked my key in the trunk once. Ended up prying hard enough on the seat back to bend the frame and reach the pull straps to drop the rear seat. It was a lesson I remember every time I have to try and latch the rear seat back upright haha.
Old 11-24-2022, 01:03 AM   #6
Sasquachulator
Pavement Grey
Originally Posted by AJ32162 View Post
Try this:
Was that switch not accessible or something in the early cars?
I also know they didnt provide an external trunk opening button until later as well.
when the car first came out the only way to open the trunk was through the keyfob right?
Old 11-24-2022, 03:04 AM   #7
orz
orz's Avatar
Drives: Halo
You could buy an ebay key like one of those keyfobs, then get it cut at the dealership. They charge about 20bucks. It wont start your car unless you program it but i'll open your trunk.
orz is offline   Reply With Quote
Old 11-24-2022, 03:24 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
IDK my cars trunk can open with the keyfob, the key, a button on then dash, and the mentioned buttons on the rear seats. Been that way since the factory. 2013 old enough to part of the recall.
Old 11-24-2022, 08:20 AM   #9
Goodcake
Drives: None
Thanks for the help everyone! unfortunately my car only came with one key fob and a valet key so i was SOL but that seat trick worked like a charm.
The Following 2 Users Say Thank You to Goodcake For This Useful Post:
DarkPira7e (11-24-2022), x808drifter (11-25-2022)
Old 11-24-2022, 08:32 AM   #10
DarkPira7e
DarkPira7e's Avatar
Same case with my 2013. Fob, dash button, key access under trunk garnish. I was actually surprised that there's no trunk release button on the interior for my 2019 Impreza. I didn't know about those seat buttons, I checked mine just now and they work, hahaha.
Old 11-24-2022, 11:41 AM   #11
Sasquachulator
Pavement Grey
i see
It must have been something i read or heard about where you couldnt folddown the trunk from inside, had to be from inside the trunk.
People must have overlooked those buttons cuz i definately saw them when i got my 86 and was like....I can drop the seat from inside.......i thought that wasnt a thing.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Old 11-24-2022, 12:48 PM   #12
That hack has always been around. You just had to know to pull the cover to get to it
There has always been a dash button on all versions
The button always existed with the keyless entry cars. That would be BRZs and Special Edition FRS until Toyota did two trims on the 86.
The trunk has always been able to opened with the key no matter what year or model.
Dake (11-24-2022), x808drifter (11-25-2022)
Old 11-24-2022, 07:36 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I'm confused. Didn't they all have keyless entry? My '15 base has keyless entry and a trunk button on the fob.
Old 11-24-2022, 08:54 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
LIFE HACK!
Trunk Cancel Button Pressed, But Lock Seized DjDATZ Issues | Warranty | Recalls / TSB 18 10-20-2021 09:19 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 10:50 AM
Small trunk lock hint here ……. humfrz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 05-29-2016 05:52 PM
Found: FRS trunk, please lock thread R3AP3R_Playz Want-To-Buy Requests 1 05-16-2016 06:24 PM
Keyless Lock Problem bdbx18 Electronics | Audio | NAV | Infotainment 5 01-18-2013 12:29 AM
