Old 10-22-2017, 02:46 AM   #43
BaatLuk
Drives: Evo X
Sorry to bump an old thread. Wondering how these will work with the OEM Sachs dampers that come with 17+ Performance Pack? Will they void the factory warranty (on shocks)? Too bad the pics are no longer available.
BaatLuk is offline   Reply With Quote
Old 10-22-2017, 10:44 AM   #44
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
They should work the exact same as with the 2013-2016 shocks.
Warranty wise, unless the dealer installs it, they will most likely will void your warranty for only that particular part (i.e shocks)....but they are meant to work with the stock suspension so you shouldn't run into any issues.
Here are some pictures of my STI Pink Springs installed. (Before & After)
15mm Drop.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following 3 Users Say Thank You to Mr.Impreza For This Useful Post:
BaatLuk (10-23-2017), JDM4E (03-25-2018), Teseo (10-22-2017)
Old 10-23-2017, 03:52 PM   #45
BaatLuk
Drives: Evo X
@Mr.Impreza, thank you! Car looks great with the STI springs! Interesting that you went with the STI springs instead of the TRD ones (rebranded Eibach pro-kit?), which are available in the US.
Japanese retail is <$200 USD for a complete set of 4. I am planning to travel to Japan in the near future and pick up a set. Anyone know where/how I can purchase STI parts in Japan?
Old 10-24-2017, 10:23 AM   #46
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Thanks
I wanted a minor drop that would work with the stock shocks and improve handling while maintaining comfort.
TRD springs dropped the car more than I preferred.
Overall, I prefer everything STI over TRD on this car apart from the TRD Spoiler. STI just seems to engineer better parts than TRD on this platform. Maybe it's due to the car coming from the Subaru Factory.
The Following User Says Thank You to Mr.Impreza For This Useful Post:
BaatLuk (10-25-2017)
Old 10-24-2017, 04:08 PM   #47
DSOmegaX
DSOmegaX's Avatar
Originally Posted by Mr.Impreza View Post
Thanks
Depends on which region you’re talking about. TRD Japan’s parts are completely different than TRD USA. Just as how WRX STI parts from US STI (SPT) we’re pretty subpar compared to STi Japan. They’re different manufacturers/suppliers.
TRD Japan's springs are the same 15mm drop as the STI pinks. Its the USDM springs that are 1"-1.5"
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Old 10-24-2017, 05:13 PM   #48
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Wow, never even knew they had springs that only dropped the car 15mm. Thought they just had that Sportivo Coilover set that dropped the car by 10mm.
Old 03-16-2018, 04:20 AM   #49
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
does anyone know a source other than japanparts.com? the shipping alone is almost 150 bucks...
jbsali is offline   Reply With Quote
Old 03-16-2018, 09:50 AM   #50
Vital
Drives: 2015 BRZ
You can get these USDM STI Pink Springs, but keep in mind they only lower the car 10mm instead of 15mm like the JDM Pink Springs...
https://www.oempartstoyou.com/oem-pa...-mt-b2010ca000
The Following User Says Thank You to Vital For This Useful Post:
jbsali (03-16-2018)
Old 03-23-2018, 05:08 PM   #51
gpvecchi
gpvecchi's Avatar
Could you please post the center wheel/fender height for front and back with STis?
Thanks!
Old 03-28-2018, 11:35 PM   #52
blackstripe77
Can anyone comment further on the ride quality of the pink springs? I'm looking for a mild drop, but the stock setup is already quite busy over rougher surfaces, and already have a hard time keeping the wheels on the ground over bumps through corners. Preferably these would be an improvement in both ride comfort and roadholding!
blackstripe77 is offline   Reply With Quote
Old 04-20-2018, 03:20 AM   #53
BaatLuk
Drives: Evo X
Will the USDM STI pink springs fit and work well with the PP Sach dampers?
Old 04-20-2018, 10:20 AM   #54
Vital
Drives: 2015 BRZ
I tagged you in the other post, but from the ad it says the USDM Pink Springs are not applicable for PP and Ts models. i honestly i have no idea why they wouldn't be
Old 11-22-2022, 07:46 PM   #55
Balefire
Drives: Mazda 93 RX7 R1
Bump old thread.
Anyone know if the USDM STI pink springs were a port installed or dealer installed option?
Asking for SCCA DS stock street purposes.
Thanks!
'93 Mazda RX7 R1. '23 Acura Integra. '23 Subaru BRZ base.
'17 Subaru BRZ PP (retired)
Balefire is offline   Reply With Quote
Old 11-22-2022, 08:33 PM   #56
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Balefire View Post
Bump old thread.
Thanks!
Dealer, and from the STI category to boot. No BRZ got lowering springs that were street class legal.
Just come to stx, the water is fine
ineedyourdiddly
norcalpb (11-22-2022)
OEM BRZ springs? jm1681 Brakes, Suspension, Chassis 1 11-03-2012 08:14 AM
Anyone use the JDM/Sti springs? G4mb17 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-25-2012 08:10 PM
HELP:Q about springs Obja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 10-08-2012 02:12 PM
trd springs or no? FT86R Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-30-2012 03:52 PM
STi Springs illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-14-2012 01:19 PM
