#1191 | |
Drives: '22 BRZ
I'm sure it won't, but you'd remove the ceramic coating then reapply. I find that less destructive than drilling holes
| The Following 2 Users Say Thank You to DocWalt For This Useful Post: | OkieSnuffBox (11-18-2022), PhatFreshPrince (11-18-2022) |
#1192 |
Drives: '23 BRZ Limited
True, but it's a moot point now. As you can't install the OEM duckbill/tail without drilling holes in the existing spoiler. Well I guess I could cut the studs off. But I pick it and my wheels up today from being ceramic coated.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#1193 | |
Drives: X5 35d, D90, CX-5 Turbo
Sure you can.. (Start around 4 min mark to watch removal of the studs) |
#1194 | |
#1195 |
Drives: 2022 MT Neptune GR86 Prem.
#1196 | ||
But then he installed Catless header's and front pipe, and I no longer liked it. I pretty much have not cared for any of his mods since, but to each their own, he probably wouldn't like my choice in mods either..
#1197 |
Drives: 2023 BRZ Limited 6MT
Cheers all - I've had my 2023 Limited 6MT for a month now, and with 900 miles on it I'm almost out of 'rev-jail'. Immediate mods so far:
1. I sourced a genuine spare wheel/tire combination; new wheel from Subaru and spare tire from Tire Rack. 2. The active sound is turned off - dealer says it was a switch on the back of the ECU of all things. 3. I now have a "winter set" of 17x8 Enkei TS10s, in a -45 offset with 225/45/17 Continental Extreme Contact DWS06+. Standard 18s are hibernating in the garage. 4. MTEC shifter and clutch springs ready to install soon, and will fit a Sprint Booster to get rid of the lazy throttle pedal. Pretty standard list for starter type stuff, won't go too much farther while the car is still under warranty. |
#1198 |
Just keep in mind the manual says to keep the revs below 4k "unless in case of emergency."
#1199 |
#1200 |
Drives: 18 Brz (Sold) / 22 BRZ
Winter tires on with 13 Brz 17” wheels
#1201 |
Drives: Peel P50
![]() Put on winters today |
| The Following 3 Users Say Thank You to vancopime For This Useful Post: |
#1202 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | OkieSnuffBox (11-20-2022), soundman98 (11-20-2022) |
#1203 |
Drives: 22 BRZ
#1204 |
Drives: Peel P50
| WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 11:36 PM |
| Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 03:51 PM |
| just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 11:05 PM |
| TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 02:16 AM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
