Old 11-09-2022, 07:01 PM   #4719
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
Oil leak on rear SC
Hey everyone! I'm hoping the image is clear, cell phone ain't the best for this lol. Anyhow, I've got a class 1 leak on the rear of my Edelbrock. I want to get it resealed but Edelbrock says they don't have repair parts or instructions. It's the flat plate on the top rear. Is this a gasket seal or RTV? I'm hoping this is a drain, remove, reseal, refill deal. Or is this more than I'm thinking?
Thanks y'all!
snowtaipan is offline   Reply With Quote
Old 11-10-2022, 09:12 AM   #4720
Chamaco
Drives: Silver FR-S
Originally Posted by B T View Post
How did your tuner get away with tuning it without the MAF being connected? They should've seen that in the logs.
MAF was connected, but without the MAP jumper harness. Basically, the tuner was seeing the intake temp reading from the MAF instead of the MAP (I think that's what was happening). According to the tuner, the tune was not far off (after connecting the jumper harness) and only needed minor adjustments under wide open throttle.
Chamaco is offline   Reply With Quote
Old 11-12-2022, 01:31 AM   #4721
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Thanks y'all!
Is that fuel, intercooler coolant or supercharger lube ?
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
Old 11-17-2022, 08:07 AM   #4722
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
How many of you are running CCV catch cans? and who isn't?
After my current experience with abnormal low rpm idle dips and large fluctuations in short term fuel trim (anywhere from +15% to -15% depending on how the car feels that day ), Zach thinks it is related to CCV blowback and recommends me to install Radium's catch can. Luckily I bought dual cans in the past, just need to install (any advice on how easy it is to install?).
I cleaned my MAF a few times and the problem still occurs. Supposedly I am the most extreme case of this occurring...
GPhilly is offline   Reply With Quote
Old 11-17-2022, 09:07 AM   #4723
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I was running dual catch cans from Radium for a while but only one ever picked anything up. The driver's side can is difficult to access but was the one that would pickup blow-by. So I just rerouted the passenger side catch can to use the driver's side lines and removed the catch can by the battery.
B T is offline   Reply With Quote
Old 11-17-2022, 04:21 PM   #4724
dpfarr
Drives: BRZ ts
I wish I planned that into my install. I'm not running a can and haven't seen any ill effects to cause me to now.
dpfarr is offline   Reply With Quote
Old 11-21-2022, 07:38 AM   #4725
GPhilly
GPhilly's Avatar
I saw that reading through earlier posts. I am hesitant to cut lines, as I don't want to mess up and make a line shorter than it should be.
Bare with me a few questions:
Is rerouting driver can to passenger easier to access for maintenance wise or installation wise?
Did you need to buy any extra parts or tools to do this?
Can I install this within a day?
Does the car need a retune after?
Old 11-21-2022, 09:45 AM   #4726
B T
@GPhilly
Both installation wise AND maintenance wise, it is much easier.
You will need to get some replacement hose from the autoparts store, maybe $10 at most
About 20-30 minutes
No retune necessary, this just keeps your intake lines free of oil residue.
Old 11-21-2022, 09:01 PM   #4727
Decep
Drives: 2013 FR-S Series 10
Sigh. sensing a trend with this company lol. I don't remember their customer service being terrible before the pandemic.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 11-22-2022, 05:53 PM   #4728
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by Jeff86 View Post
Christmas came early
Tell us how it drives after your installation!
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 11-24-2022, 06:11 PM   #4729
dpfarr
Drives: BRZ ts
@GPhilly
About 20-30 minutes
I don’t imagine an hour is reasonable if the blower is already installed? Getting access under the drivers side runners is excessively inaccessible for getting a replacement hose on I assume.
Old 11-25-2022, 01:02 PM   #4730
B T
I don't remember having any trouble snaking my hand in from the passenger rear side of the blower to get the line on, but could be wrong.
Old 11-26-2022, 10:26 PM   #4731
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I definitely will! Engine started and revved nicely! Mechanically everything looks great! While I had the bumper off I decided on new headlights and install of TRA-Kyoto brake ducts. Had to wait on those, but I’ve got them now and they look amazing. They required quite a lot of finessing to get them right… oscillating tool, dremel and sanding.
I can’t wait to drive her! Bumper should be back on tomorrow!
Jeff86 is offline   Reply With Quote
Old 12-04-2022, 12:52 PM   #4732
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Finally got her all finished up and... OMG... the fun factor for this car has gone off the scale! On a tank of E85 it rips to redline. I can easily break traction on my stickier Yoko Advans. There's much more power throughout the rev range, but the top end is nuts. No torque dip and power application is linear and predictable. As many have said, it solves this car's lack of power problem entirely. I'm able to hear a tiny bit of whir sound in the higher rpms from the blower at wot. I think it's mainly because I have a fairly quiet exhaust. I also added crackle and pop on this tune... which is super fun haha. I waited a long time to do this and even contemplated selling the car. I couldn't be happier with it now! Well worth the money for this particular supercharger.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
