Old 10-27-2022, 12:58 PM   #4705
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Christmas came early
Jeff86 is offline   Reply With Quote
Old 10-28-2022, 03:33 PM   #4706
86Andy
Drives: 2013 Hot Lava FR-S
Originally Posted by CallmeDave View Post
We got the new bypass valve installed. We found it easier to remove the AC condenser to gain access to install the bypass with the bracket installed.
Also note the size the difference in the old and new bypass.
I’m considering replacing my bypass valve soon and have questions regarding the install while leaving the supercharger/manifold on the engine. Were you able to get feeler gauges in there to make the adjustments on the actuator rod, even without removing the supercharger? Or can I just slap on the new vacuum actuator and leave the bracket untouched?
Had my Edelbrock on for about 3 months now and it hasn’t consistently given me boost when I want it, sometimes nothing even happens regardless of how quickly or slowly I tip into the throttle. Really hoping this is an easy bolt on once I get the AC unit off.
86Andy is offline   Reply With Quote
Old 10-28-2022, 03:38 PM   #4707
86Andy
Originally Posted by Colin86 View Post
PSA: The upgraded edelbrock bypass is relatively straight forward to install WITHOUT removing the supercharger if you remove the AC compressor. Remove the AC compressor, throttle body, engine side of the edelbrock air box, and vacuum lines into the snout of the supercharger and you have plenty of access.
After removing the above I laid a large sheet down between the engine and the bottom of the supercharger so if I dropped any bolts/nuts from the bypass/bracket they didn't fall into the abyss of the engine. I'd consider this approach significantly easier than removing the supercharger, your mileage may vary.
Just replied to a way older post before seeing this. I’ll ask the same question though—did you have space to make the actuator rod adjustments with feeler gauges? Or did you just leave the bracket and only replace the vacuum actuator? Based on the fact that my symptoms line up with a lot of these bad bypass valve posts, I’m thinking I want to try replacing it soon.
Old 11-01-2022, 10:37 AM   #4708
Chamaco
Drives: Silver FR-S
Hi guys,
I installed my kit a few months ago and have a question about the MAP wiring harness. It has two extra plugs that I don't know what they are for. can anyone explain what are they for? thanks
Sent from my SM-F711U using Tapatalk
Chamaco is offline   Reply With Quote
Old 11-01-2022, 10:38 AM   #4709
Chamaco
Drives: Silver FR-S
ah, the joy of opening the box!
Old 11-02-2022, 01:27 PM   #4710
FrickingReallySlow
Drives: 2015 FR-S
its a combo MAF and MAP harness you need to connect both sensors to that. It takes the temp sensor from the MAF and transfers it to the MAP instead. The install guide has where to connect them
Originally Posted by Chamaco View Post
Hi guys,
FrickingReallySlow is offline   Reply With Quote
Old 11-02-2022, 01:43 PM   #4711
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Hi guys,
T-map harness ?
Install manual page 7, item 3 and pages 135/136
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
Old 11-03-2022, 01:20 PM   #4712
Brewster
Brewster's Avatar
Originally Posted by Brewster View Post
T-map harness ?
Correction: Pages 35/36, steps 159-161
Old timers disease
Old 11-05-2022, 03:59 PM   #4713
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Well I didn't think I'd be having to ask this but for sanity check the bypass valve should hold a vacuum correct... I've been thinking something was up lately with just minor drivability issues and I finally got around to checking for vacuum leaks. Sprayed carb clean at anything that I could think would leak and nothing. For Shitsandgigs I figured let's check the valve and it doesn't even try to hold a vacuum. It's the updated valve that has been in the car for the last year and a half/20k and has been flawless until now. Guess I really should've installed that relocation kit I got from BT a while back
aKaGorganZola is offline   Reply With Quote
Old 11-07-2022, 10:23 AM   #4714
Chamaco
Drives: Silver FR-S
Thank you guys for the responses. Will check the install guide today.
Old 11-07-2022, 10:43 AM   #4715
Chamaco
Drives: Silver FR-S
Thanks again @FrickingReallySlow and @Brewster. Now that I'm thinking about it, it was tuned without the MAF being connected to the harness. By connecting like it's supposed to, will that affect the tune in any way?
Old 11-08-2022, 10:55 PM   #4716
Brewster
Brewster's Avatar
I'd ask your Tuner
Old 11-09-2022, 09:17 AM   #4717
Chamaco
Drives: Silver FR-S
I'd ask your Tuner
thanks. I did soon after writing my post in here. Yes, it affected the tune a bit and got it revised/resolved.
Old 11-09-2022, 12:11 PM   #4718
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
How did your tuner get away with tuning it without the MAF being connected? They should've seen that in the logs.
B T is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
