Old 11-08-2022, 09:55 PM   #15
sheshanthv
Drives: 2013 subaru brz turbo
Detuning the maximum output of the engine doesn't change the fuel consumption when you aren't WOT. You can optimize the tune to be more efficient at lower throttle but it's going to suck to drive.
The problem here is the engine itself and the turbo parts have been built in a way that is specifically not efficient when off boost. Pressure at TDC = combustion efficiency. The problem with the turbo is it makes pressure by cramming more air in, which means you need more fuel or you will get crazy early detonation which would destroy your internals. NA engines make pressure with higher compression ratios so you don't need to cram as much air in.
I have read that turbos dont mess up fuel economy too bad on light throttle. Do you happen to know what part is making it like that? Also wouldnt tuning and changing compression ratios change how much air the turbo crams in? Im just trying to see if theres anything I can do here lol.
sheshanthv is offline   Reply With Quote
Old 11-08-2022, 10:04 PM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Let's start with where you read that for context. Was it something about cars that originally came with a turbo or aftermarket turbos?
Also: "Build Thread"
Old 11-08-2022, 10:15 PM   #17
sheshanthv
Well I have seen posts on this forum discussing mpg on a turbo frs or brz. And the guy was on 9lb of boost getting around 26 or 25 mpg.
Look man the car gets 18 mpg rn combined and all I wanted to know was if a tune to lower fuel injection on normal driving or anything of that sort would net me more mpg. That is all.
Old 11-08-2022, 10:32 PM   #18
Spuds
The Dictater
Spuds's Avatar
Short answer, no.
Long answer noooooooooooo.
If you can give a link to the post, maybe someone can help.
Edit: Ok, I can probably tell you what's wrong. Compression is too low. Valve springs too stiff. Probably more engine internals set for power and not efficiency. Wheels too wide, and you could probably put on touring tires rather than performance tires which I assume it has. Don't know about turbo sizing but smaller is usually more efficient.
Old 11-09-2022, 01:16 AM   #19
pope
has a funny hat
Drives: 2014 BRZ Limited
hah yeah well im really pushing to make it work, cuz this specific car has been like my intro into the car scene, and I wont lie i have been so jealous of my friend for getting it, so im gonna try my best and make it work.
You can keep ignoring all of us that have given you the facts about these cars or you can take the recommendations and move beyond the childish “scene” culture and become a true car person.
Here is the hard truth, if gas prices and fuel economy concern you, it’s out of your budget. Unless you have real money in college, you shouldn’t have a modified car.
But, if you absolutely have to own this BRZ, your solution is to sell the built engine and turbo kit and replace it with a stock engine. Then, if it has any other aftermarket parts on it that’ll kill fuel efficiency (e.g. park bench wing, heavy wheels, wide tires, body kits, etc.) you need to remove them.
No amount of tuning is going to fix the fuel economy without blowing the engine the first time you step on the gas.
pope is offline   Reply With Quote
Old 11-09-2022, 11:29 AM   #20
Looking at the parts list in that car it has been built to use ever single aftermarket "upgrade" in the catalogue. It is going to be a gas hog no matter what is done to it. END OF STORY. You could not pay me to drive that thing as a DD.
Of course putting a stock engine in it will lose "car scene" street cred and Instagram likes so the car is useless if that is done.
Of course it is also hard to be part of the crowd when your Super Car is sitting behind the garage with a tarp over it because you tried to down tune it and blew the engine up but can't afford repairs.
But it appears we are all just...
Old 11-09-2022, 12:21 PM   #21
pope
has a funny hat
He couldn’t get the answer he wanted here, so he went to the middle-school brain trust on Reddit.
https://www.reddit.com/r/ft86/commen...turbo_brz_mpg/
Old 11-09-2022, 12:24 PM   #22
Per usual
I have never been there and don't plan to now.
Old 11-09-2022, 04:47 PM   #23
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Per usual
I have but only really go to
r/iiiiiiitttttttttttt (it is spelt like that for a reason)
r/airsoftcirclejerk (110% troll thread)
r/systemadmins
r/WinStupidPrizes
Old 11-09-2022, 08:07 PM   #24
Lantanafrs2
Drives: 2013 frs red
If you're concerned with fuel economy, you probably won't be able to afford another motor, which will be needed at some point.
Lantanafrs2 is offline   Reply With Quote
Old 11-09-2022, 09:11 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
BECAUSE IT'S NOT IN BOOST.
Old 11-09-2022, 09:12 PM   #26
soundman98
ProCrastinationConsultant
soundman98's Avatar
funny how that is starting to spiral the same way this did...
almost like he's trying to find the answers he wants instead the answer he needs...
Old 11-09-2022, 09:52 PM   #27
Apolllo
Drives: 2018 Subaru BRZ Limited
Whats the point of having a turbocharged car if you never drive it in boost?
Apolllo is offline   Reply With Quote
Old 11-09-2022, 09:58 PM   #28
soundman98
soundman98's Avatar
Be SuRe To LiKe AnD sUbCrIbe!!!!!!!!!!!!!!!!
brz, mpg, part, question, turbo
Help figuring out my brake problem Jfheisenberg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-10-2022 02:07 PM
Where to purchase 2017 86 Parts Slammedsteve Scion FR-S / Toyota 86 GT86 General Forum 18 12-14-2016 11:42 PM
Need help figuring something out Jrevans1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-30-2016 12:56 PM
Need help figuring out if I can afford an FR-S. BrianFRS Scion FR-S / Toyota 86 GT86 General Forum 57 03-31-2014 08:55 PM
website/store to purchase pre-painted body parts supramkivtt2jz Scion FR-S / Toyota 86 GT86 General Forum 6 07-30-2013 09:13 AM
