| Software Tuning Discuss all software tuning topics. |
Drives: Toyota 86 2017 Facelift
Hi everyone,
My car is the Toyota 86 2017 Facelift model. Without enough research, I went ahead and flashed 2013 rom on the ECU which may have bricked my ECU. I am unsure if it's fully bricked as I am still able to read and write to the ECU using ECU FLASH. However my engine no longer starts. I have seen a post from steve99 https://www.ft86club.com/forums/show...10&postcount=1 that says, "K00x roms are for 2017 cars only, do not flash earlier roms to 2017 cars else you will trigger a security lockout and car will not start . you will need to perform the ECU replacement ecu resync proceedure to get car to start after flashing back a 2017 rom." Things I have done, - Removed battery and insert back - Flashed 2017 Roms - Flashed my stock rom with no definitions (create from scratch) None of these has worked because the ecu is probably in security lock mode. Is there anyone who knows how to reset the ecu so that I can remove the security lock mode and start my engine? As of now, my ecu is flashed with my stock rom which is ZA1JK01B Would really appreciate you guys on your inputs to this thread.
#2 |
Drives: brz 2017 hksv2
here procedure
https://www.ft86club.com/forums/showthread.php?t=102810 |
#3 |
Drives: WRB BRZ
As Tom says above use that proceedire to rescny security
Flash back a Stock rom then Just perform steps 7 through to 14 in the procedure above That will rescnc the security and car will Start, done it several times will be fine Last edited by AussieBRZ; 11-07-2022 at 03:32 PM. |
#4 |
Thanks so much for the replies guys. Glad to know this is the solution. I will update once I get my hands on a jumper.
Is anyone also able to answer if ZA1JK01B car is compatible with ZA1JK00G rom from OFT? |
#5 | |
Drives: WRB BRZ
If it's a 2017-2021 manual then K00G will work If it's auto 2017-2021 then use K01I Last edited by AussieBRZ; 11-08-2022 at 05:17 AM. |
#6 |
Just a bit of an update, the solution provided by tomm.brz & AussieBRZ worked. I have flashed K00S onto my car and it worked just as fine.
#7 |
credit to him, he did all the job. Thanks Steve
| Tags |
| 2017, ecu flash, facelift, flash, roms |
| New engine start up | Nintain | Engine, Exhaust, Transmission | 3 | 09-25-2022 08:59 PM |
| Joying 7" head unit in MY2017 BRZ | Acuario | Electronics | Audio | NAV | Infotainment | 1 | 12-13-2019 05:26 AM |
| FS: STI engine start push start OEM plug and play | sokol | Interior Parts (Incl. Lighting) | 5 | 06-13-2019 02:12 PM |
| MY2017 exhaust difference?! | Warlin | Engine, Exhaust, Transmission | 7 | 12-24-2017 02:18 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
