-   Software Tuning (https://www.ft86club.com/forums/forumdisplay.php?f=88)
-   -   Engine Won't Start (ECU FLASH) MY2017 (https://www.ft86club.com/forums/showthread.php?t=151800)
kasugasorata98 11-07-2022 02:30 PM
Hi everyone,
My car is the Toyota 86 2017 Facelift model.
Without enough research, I went ahead and flashed 2013 rom on the ECU which may have bricked my ECU. I am unsure if it's fully bricked as I am still able to read and write to the ECU using ECU FLASH. However my engine no longer starts.
I have seen a post from steve99 https://www.ft86club.com/forums/show...10&postcount=1
that says, "K00x roms are for 2017 cars only, do not flash earlier roms to 2017 cars else you will trigger a security lockout and car will not start . you will need to perform the ECU replacement ecu resync proceedure to get car to start after flashing back a 2017 rom."
Things I have done,
- Removed battery and insert back
- Flashed 2017 Roms
- Flashed my stock rom with no definitions (create from scratch)
None of these has worked because the ecu is probably in security lock mode.
Is there anyone who knows how to reset the ecu so that I can remove the security lock mode and start my engine?
As of now, my ecu is flashed with my stock rom which is ZA1JK01B
Would really appreciate you guys on your inputs to this thread.
:thanks:
tomm.brz 11-07-2022 03:05 PM
here procedure
https://www.ft86club.com/forums/showthread.php?t=102810
AussieBRZ 11-07-2022 04:21 PM
As Tom says above use that proceedire to rescny security
Flash back a Stock rom then
Just perform steps 7 through to 14 in the procedure above
That will rescnc the security and car will Start, done it several times will be fine
kasugasorata98 11-07-2022 09:07 PM
Thanks so much for the replies guys. Glad to know this is the solution. I will update once I get my hands on a jumper.
Is anyone also able to answer if ZA1JK01B car is compatible with ZA1JK00G rom from OFT?
AussieBRZ 11-08-2022 06:05 AM
If it's a 2017-2021 manual then K00G will work
If it's auto 2017-2021 then use K01I
kasugasorata98 11-09-2022 09:30 AM
Just a bit of an update, the solution provided by tomm.brz & AussieBRZ worked. I have flashed K00S onto my car and it worked just as fine.
tomm.brz 11-09-2022 10:13 AM
credit to him, he did all the job. Thanks Steve
