Old 09-09-2021, 11:28 PM   #57
StraightOuttaCanadaEh
Wes
Okay so just to confirm, 95% of the vibration is gone with the diff bushing inserts removed. Prolonged driving at 86 mph did not produce any, none that could be telegraphed to the cabin anyway.
Instagram: @gt86ws
The Following 4 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Dzmitry (09-10-2021), FrickingReallySlow (09-10-2021), Ohio Enthusiast (09-10-2021), zc06_kisstherain (09-13-2021)
Old 09-10-2021, 12:53 AM   #58
gpvecchi
gpvecchi's Avatar
Anybody on STi bushings with carbon driveshaft?
Old 09-17-2021, 01:11 AM   #59
gpvecchi
gpvecchi's Avatar
For those with a one piece driveshaft and MT, can you measure the pinion angle?
Old 09-28-2021, 10:14 PM   #60
Yoniyama
Drives: BRZ 2018
I am a happy customer with a Versus carbon driveshaft for automatic transmission. The only suspension modification is the brace for differential. Absolutely no vibration problem at any speed (up to 100 mph). The quicker acceleration from the lower rotational mass is noticeable.
Yoniyama is offline   Reply With Quote
Old 01-03-2022, 09:50 PM   #61
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Originally Posted by billstock67 View Post
Received new driveshaft & installed yesterday. Much different design from pictures on website. They assured me it was fully tested, and stronger than previous. Not sure why that was needed, or what they are correcting. Weight now over 15 lb. Have vibration at 80 mph and over. Waiting for Verus response.
Try tightening the DS bolts that hold the DS to the yoke. Apparently makes a big difference re vibration issues. It's a pain in the arse to get them properly tensioned. Tension the bolt and NOT the nut in this instance. You can also rotate the DS 90 or 180 deg to see it that helps.
Do you have any other mods to the GB or diff mounting. Inserts or replacement bushes for example?
Had no such issues with mine which was delivered and installed in November '21. Having bought a lot of Verus stuff, if they make it then it's 100% right.
Bodalenko is offline   Reply With Quote
Old 01-03-2022, 09:54 PM   #62
Bodalenko
Steve Bodalenko
One hundred percent correct re the quicker acceleration due to lower rotational mass. I was really surprised how noticeable it was..
Old 01-03-2022, 10:03 PM   #63
Bodalenko
Steve Bodalenko
Originally Posted by VerusEric View Post
That is correct, we will no longer be producing them.
I believe your issue to be specific to your vehicle. I have personally not heard of a balance issue to date from our units, let alone two units back to back. Like others in this thread stated, it can be a variety of things.
Thanks,
Eric
I'd heard that before I pulled the trigger on mine. That leaves very few manufacturers. In my experience well worth the effort of changing to one. Pretty sure Verus are seen as by far the best.
Old 01-03-2022, 10:10 PM   #64
Bodalenko
Steve Bodalenko
I have the STI engine mounts and Whiteline GB upgrade with my CF DS.. I also have the Whiteline subframe inserts.
I also have the IRP shifter to add to the rattle/NVH battle!
I did have the diff inserts but removed them due to NVH. Having said that apparently just installing the rear diff inserts does not result in NVH.
The Following User Says Thank You to Bodalenko For This Useful Post:
gpvecchi (01-04-2022)
Old 11-04-2022, 08:47 AM   #65
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Verus driveshaft discontinued? What to buy?
Verus site page for our driveshaft says "*Manual Driveshafts are no longer in production*".
Now what?
I was about to order the PST, over the Driveshaft Shop's, because of weight difference. DSS lists theirs as 25 pounds and PST says 13.9 pounds.
I'm never going to go for huge power so I see no reason not to buy the PST.
FYI, I am road racing and not drag racing.
Thoughts?
Scargod is offline   Reply With Quote
Old 11-04-2022, 09:21 AM   #66
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
No. They list stock as 24.something, I think theirs weighs 12.9. check again
Old 11-04-2022, 09:50 AM   #67
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Now what?
Thoughts?
I would wonder what the critical speed on the DSS carbon shaft is since the aluminum one is pretty low.
The Following User Says Thank You to dragoontwo For This Useful Post:
blsfrs (11-04-2022)
Old 11-05-2022, 10:37 AM   #68
Scargod
Track Day Junkie
Scargod's Avatar
Not sure where your info is coming from, but the response from Verus is that they are discontinued because of the exorbitant cost to make them. They have two for automatics in stock and that's it.
As to wondering what the critical speed (RPM's I assume) on the DSS carbon shaft or saying that the aluminum one is rated as low, I have no idea what dragoontwo is referring to. I've only seen power ratings.
Old 11-05-2022, 10:59 AM   #69
DarkPira7e
DarkPira7e's Avatar
I think you misunderstood, I was only talking about the weight of the DSS driveshaft. Maybe I misunderstood? Haha
Old 11-05-2022, 03:27 PM   #70
dragoontwo
dragoontwo's Avatar
Here's some light reading about their aluminum shaft.
https://www.ft86club.com/forums/showthread.php?t=148537
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft Brzzee Transmission and Driveline 1 09-14-2018 09:22 AM
Driveshaft Shop Carbon Fiber Driveshaft (MT) $650 [SOLD] acj47 Transmission and Driveline 2 10-25-2017 05:07 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
