#15 |
Be Kind
Drives: 2020 86
No clue LOL. I'm sure someone will chime in with it. I'm afraid the answer will be throw out bearing but we'll see.
#16 |
Yeah - I'm back to thinking TOB. Unfortunately it's a known weak point on the earlier cars.
#17 |
It's a weak point on all of 'em. Does the sound change when you tap the clutch pedal?
Not brakes. Periodicity is too high. Sounds like the driveshaft is rubbing on something.
#18 | |
Drives: 2014 Scion FRS
plus i already replaced the clutch and TOB about 20k miles ago |
#19 |
Drives: 2013 pearl white FR-S
#20 | |
I didn't think it sounds like TOB. Engine braking is key. It sounds more like thin sheet metal rub/vibe. Engine/trans, all of it forward of the mid-pipe (articulating donut gasket thingy) tweaks a little bit under torque. I'd poke around there looking for something loose.
#21 | |
#22 |
Drives: 2015 midnight blue limited edition.
Any luck finding out what this was ? I have basically had the same ever since I replaced the OEM TOB with a stage 1 exedy clutch. I have noise while engining braking in the 5th, a little less in 4th and least in 1st. Goes away in neutral
#23 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Last Activity: 05-03-2021 06:48 AM Think your SOL asking them. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Tcoat (11-04-2022) |
| Tags |
| brakes, clutch, grinding, noise |
| Noise on deceleration and taking off in 1st | Dububster | Engine, Exhaust, Transmission | 7 | 10-06-2020 06:24 PM |
| Weird noise | j_ros94 | BRZ First-Gen (2012+) — General Topics | 0 | 02-26-2020 01:40 PM |
| Weird Noise | FloridaBRZ | BRZ First-Gen (2012+) — General Topics | 7 | 04-25-2014 08:35 PM |
| Weird Noise??? | caradd | Issues | Warranty | Recalls / TSB | 3 | 11-01-2013 11:42 PM |
| Odd noise on deceleration | Dipstik-sportech | Engine, Exhaust, Transmission | 7 | 08-18-2013 10:42 AM |
