Old 04-29-2021, 12:33 PM   #15
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by thatkidghost View Post
any idea what that sound is lol ?
No clue LOL.
I'm sure someone will chime in with it. I'm afraid the answer will be throw out bearing but we'll see.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 04-29-2021, 12:46 PM   #16
Dake
Dake's Avatar
Yeah - I'm back to thinking TOB. Unfortunately it's a known weak point on the earlier cars.
Dake is offline   Reply With Quote
Old 04-29-2021, 02:48 PM   #17
It's a weak point on all of 'em. Does the sound change when you tap the clutch pedal?
Not brakes. Periodicity is too high. Sounds like the driveshaft is rubbing on something.
Old 04-29-2021, 05:59 PM   #18
thatkidghost
Drives: 2014 Scion FRS
when i tap the clutch no but when i throw it in neutral it quiets down. only when engine braking though when im on the gas or shifting gears it doesnt make a sound. and when the car is hot it also goes away. im stumped
plus i already replaced the clutch and TOB about 20k miles ago
thatkidghost is offline   Reply With Quote
Old 04-29-2021, 06:36 PM   #19
DarkSideFRS
Drives: 2013 pearl white FR-S
20k miles is prob halfway thru the TOB life expectancy on these cars lol
DarkSideFRS is offline   Reply With Quote
Old 04-29-2021, 07:03 PM   #20
Well, shit.
I didn't think it sounds like TOB. Engine braking is key. It sounds more like thin sheet metal rub/vibe. Engine/trans, all of it forward of the mid-pipe (articulating donut gasket thingy) tweaks a little bit under torque. I'd poke around there looking for something loose.
Old 04-29-2021, 07:17 PM   #21
thatkidghost
Well, shit.
will do ill have to jack it up and see. thats why i initially thought brakes.. sounds like somethings rubbing or scraping while engine braking
Old 11-03-2022, 10:50 PM   #22
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Any luck finding out what this was ? I have basically had the same ever since I replaced the OEM TOB with a stage 1 exedy clutch. I have noise while engining braking in the 5th, a little less in 4th and least in 1st. Goes away in neutral
dynarun55 is offline   Reply With Quote
Old 11-04-2022, 06:58 AM   #23
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Last post was from 04-29-2021 01:17 PM
Last Activity: 05-03-2021 06:48 AM
Think your SOL asking them.
brakes, clutch, grinding, noise
Noise on deceleration and taking off in 1st Dububster Engine, Exhaust, Transmission 7 10-06-2020 06:24 PM
Weird noise j_ros94 BRZ First-Gen (2012+) — General Topics 0 02-26-2020 01:40 PM
Weird Noise FloridaBRZ BRZ First-Gen (2012+) — General Topics 7 04-25-2014 08:35 PM
Weird Noise??? caradd Issues | Warranty | Recalls / TSB 3 11-01-2013 11:42 PM
Odd noise on deceleration Dipstik-sportech Engine, Exhaust, Transmission 7 08-18-2013 10:42 AM
