Old 10-03-2020, 07:05 PM   #1
Dububster
Dububster's Avatar
Noise on deceleration and taking off in 1st
I recently noticed a really strange loud sound coming from the passenger side of my BRZ and have no clue what it could be and figured I check with the wise men of this forum. The noise is most noticeable when taking off in first in the low rpms, when taking my foot off the gas, and sometimes when I first start the car up. I have a gruppe S header and the rest of the exhaust is stock. Also have a oft on stage 2 E85 if that means anything. Here’s a link to a video of the sound of that helps at all. Thanks in advance
Dububster is offline   Reply With Quote
Old 10-03-2020, 11:20 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Regarding passenger side .. isn't that the place where soundtube is passed in? Plug it off for experiment sake using "free" cap from lighter 12V socket in glovebox.
Old 10-04-2020, 03:18 AM   #3
Dububster
Dububster's Avatar
Already did that. Thank you though
Old 10-04-2020, 11:24 PM   #4
humfrz
Is the sound related to engine speed?
Related to car speed?
Does it make that sound if the car is not moving?
Come back.
Old 10-05-2020, 08:43 PM   #5
Dububster
Dububster's Avatar
Come back.
It seems worse in lower rpms when taking off in first and is only audible at low speeds. The sound is there when idleing but it is much quieter.
Old 10-05-2020, 09:30 PM   #6
Lantanafrs2
Drives: 2013 frs red
Exhaust rub?
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Dububster (10-06-2020)
Old 10-05-2020, 10:49 PM   #7
StraightOuttaCanadaEh
Wes
Check that your front pipe bolt hasn't rattled itself loose. Mine did that after I swapped the mounts and the noise was most apparent at low rpms and was coming from the door area, driver or passenger.
Instagram: @gt86ws
Old 10-06-2020, 06:24 PM   #8
Dububster
Dububster's Avatar
Originally Posted by Lantanafrs2 View Post
Exhaust rub?
You were right, thank you so much!
The Following User Says Thank You to Dububster For This Useful Post:
Lantanafrs2 (10-06-2020)
Review: Deceleration-sensing brake flasher. catsspat Cosmetic Modification (Interior/Exterior/Lighting) 28 12-27-2016 11:07 AM
Engine tapping sound on deceleration qtwre Engine, Exhaust, Transmission 5 05-09-2016 03:52 PM
TC + CEL light on high rpm deceleration Agent_D Issues | Warranty | Recalls / TSB 29 04-29-2016 08:17 PM
car jerks to right on deceleration ikeryder13 Issues | Warranty | Recalls / TSB 25 02-15-2016 02:00 PM
Odd noise on deceleration Dipstik-sportech Engine, Exhaust, Transmission 7 08-18-2013 10:42 AM
