Old 11-01-2022, 04:17 PM   #99
RedReplicant
Drives: None
So, funny story...
I put Whiteline bumpsteer correction balljoints and tie rod ends into the car a couple of weeks ago so I also threw in SuperPro caster correction and flca rear bushings into the arms since they were out.
I lowered the car to roughly SuperMiata/949 recommended height but ended up putting the front way lower than I meant to because my pinch welds up front were smashed higher than I realized at the time.
Front:
Fender to ground: 24 3/4"
Pinch to ground: 5" / 127mm (this is clearly wrong based on fender to ground delta)
Rear:
Fender to ground: 25 7/16"
Pinch to ground: 5 3/16" / 132mm
I also had the car aligned to -3.75* / -2.75* and 0 toe all around.
For whatever reason the car did not cut EPS the entire weekend. I have no explanation.
Car would not put down power in 2nd gear exit corners and was super loose after going on throttle mid corner in 3rd/4th gear corners, but I attribute that to the way higher than intended rake and the turd-ass AR1s.
Either way, interesting. We will see if it holds through the bowl at Chuckwalla in two weeks.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
gt5759 (11-01-2022), ML (11-02-2022)
Old 11-02-2022, 12:46 PM   #100
RedReplicant
Drives: None
I talked to the guy that makes these today: https://www.nmstec.ca/product/psc/
He said the issue is power delivery and that he was able to replicate the cut out on his bench. Apparently, the unit demands a bunch of assist at first movement then drops down, which causes a big demand draw up front and leads to the cut out. He says that his unit doesn't create the initial demand spike, which prevents the issue from happening.
gt5759 (11-03-2022), whataboutbob (01-04-2023)
Old 11-02-2022, 02:08 PM   #101
Nmstec
Drives: Frankenstein of parts
Ohi <3 I can show the simulation upon my return home, where I create a quick input against a decent load at 50% assist, and it would simply restart the EPS module. It uses a steering angle sensor(external) along with internal torque sensor to do a quick "boost" in assist. If the load is big enough, and voltage drops below 11v, the whole unit decides a restart is in order.
Nmstec is offline   Reply With Quote
The Following 7 Users Say Thank You to Nmstec For This Useful Post:
bcj (11-02-2022), DarkSunrise (11-03-2022), DocWalt (11-04-2022), gt5759 (11-03-2022), ML (11-03-2022), RedReplicant (11-02-2022), whataboutbob (01-04-2023)
Old 11-03-2022, 12:50 PM   #102
gt5759
Drives: 2017 BRZ
Here is what we have been using on several builds, I figured all this stuff was a little more known but I guess not! https://www.brunosteering.com/produc...ller-kit-epas/
They also have fancier versions with gps speed control or you can operate it with a haltech or any other stand alone engine management.
gt5759 is offline   Reply With Quote
Old 11-03-2022, 01:18 PM   #103
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
This unit solves the problem of the power steering cutting out momentarily with high grip tires?
terboboost is offline   Reply With Quote
Old 11-03-2022, 05:01 PM   #104
gt5759
Drives: 2017 BRZ
Yes, they run Hoosier R7's. I have some theories as to what is happening, but I am no electrical/software engineer.
Old 11-03-2022, 05:33 PM   #105
eb66
Drives: 2015 FRS
Glad to hear there is a cheaper option that works. Thanks for sharing.
eb66 is offline   Reply With Quote
Old 11-14-2022, 12:24 PM   #106
RedReplicant
Drives: None
Update on my issue disappearing with the stock EPS / stock controller, it was there at Chuckwalla. Cut in a handful of corners every lap, the bowl was terrible.
Old 11-14-2022, 12:31 PM   #107
Nmstec
Ehhh not quite. His unit does have analog input, but not meant for PWM control.
Old 11-14-2022, 01:12 PM   #108
gt5759
Drives: 2017 BRZ
Yeah, we use the Haltech via analog voltage for control and remove the switch he sends. For most the rotary switch he sends should be adequate, the other way is just fancier and don't have an external knob. All I know is it works great for a race car application as we don't have steering cut.
Old 11-14-2022, 04:22 PM   #109
Nmstec
Hey while I'm here, may as well compare my **** size with brunos lol.
Here's demo UI for my controllers in case someone needs slightly more features:
psc-demo.nmstec.ca/
The Following User Says Thank You to Nmstec For This Useful Post:
DocWalt (11-15-2022)
Old 01-03-2023, 11:15 PM   #110
amirnew
Drives: 2013 BRZ sprintex SC
After the suspension changes?
amirnew is offline   Reply With Quote
Old 01-03-2023, 11:36 PM   #111
amirnew
psc-demo.nmstec.ca/
Your unit can work with canbus and not cause any fault codes?
Is there an option\map that mimic the oem steering wheel ,without the peak current at initial turn?
Old 01-04-2023, 12:19 AM   #112
Nmstec
The module itself simply allows the power steering system to operate under whatever conditions you like. If you want to integrate it back into the the same car (like the BRZ and redreplicant did), I allow that, and will supply you with custom firmware that gets rid of the EPS light.
Control can be done in whatever method you like, potentiometer, canbus control, canbus VSS map, anything you can think of.
The peak current is not done by my controller, it is done directly with the OEM steering system when you do a fast input (high torque, high assist). You can simply dial down the assist with my controller, that in turn will also produce a lower current peak during fast inputs.
rattling when braking Latiii Issues | Warranty | Recalls / TSB 14 08-07-2014 12:16 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
Braking Issue In Mid Drift imravenit Tracking / Autocross / HPDE / Drifting 12 02-12-2013 03:16 AM
