Old 10-03-2022, 07:41 PM   #1
NJUL9925
Drives: 2013 FRS
How much more engine oil after oil cooler?
I purchased my car with the cooler on, I believe its a 10 row and seller told me just use an extra quart of oil. What are you guys with coolers installed adding on top of the 5 quarts and how did you go about figuring out the amount ?
thanks
NJUL9925 is offline   Reply With Quote
Old 10-03-2022, 08:18 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You figure the amount out by buying extra oil, fill until you check the level and it's on the dipstick
Old 10-03-2022, 08:22 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i usually put 5.5 quarts in to my all-oem car...
Old 10-04-2022, 07:30 AM   #4
KillerBMotorsport
KillerBMotorsport's Avatar
Fill with regular amount. Start car. Stop Car and let sit for 5 minutes. Recheck level.
The oiling system will suspend the oil in the cooler, assuming you have a proper OEM spec oil filter with the correct backflow prevention valve. So once you start the car, oil will be in the entire lubrication system, including the remote oil cooler you have. The level in the pan will drop because of this, so you can add more oil until the full mark is reached.
OR, calculate how much to add based on the oil cooler's capacity, line size, and length.
Either way will get you where you want to be.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
NJUL9925 (10-19-2022), soundman98 (10-04-2022)
Old 10-04-2022, 09:48 AM   #5
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
recheck the level and top off until it's full the first time after install. After that, the oil cooler shouldn't be draining itself empty when you change your oil because it doesn't just magically all siphon out and leave the system completely dry.
Subsequent changes, you should refill with basically the factory amount of oil and check level to make sure. And yeah, that means you have an extra quart of oil stuck in your engine between changes. Trust me, it won't kill ya.
Matt93SE is offline   Reply With Quote
Old 10-04-2022, 12:11 PM   #6
KillerBMotorsport
That depends on location and design. If it's low, it may hold oil. AMG has a drain valve on their oil coolers to accommodate this. Some designs are such that pulling the oil filter will let the oil cooler syphon out, but the FA is definitely not one.
Since we do oil changes HOT, we use a Tee and drain valve. Or if the heat exchanger has an extra port, just add a drain valve to the low side.
Old 10-04-2022, 01:22 PM   #7
Matt93SE
Yes, my comments are generic to the typical 86 cooler setup with a low-mounted cooler and top-feed hoses. Since the cooler is a fairly low point in the system, it does retain oil unless you make an effort to drain it out. depending on the adapter, it could let the oil siphon out when the filter is pulled, but some do not.
I know for certain when I unhooked my (JR) oil cooler to do some other work, I already had the oil filter off and it would have siphoned out, but noooo I got a big dang mess all over my splitter! maybe the thermostat was closed on the adapter plate guy, preventing it from siphoning?
Old 10-04-2022, 05:00 PM   #8
KillerBMotorsport
That shouldn't be able to happen. The thermostat should never be able to fully close. This is to prevent shocking a hot engine with cold oil.
Old 10-05-2022, 10:51 AM   #9
Matt93SE
:shrug: can't explain it all, just reporting what I've encountered.
Old 10-11-2022, 01:50 PM   #10
WNDSRFR
Drives: FR-S,GTI
i usually put 4.5 quarts in to my all-oem car...
Your engine must be smaller than mine. Mine takes 5 1/2 quarts every time. It's not completely oem bit still....
Old 10-11-2022, 11:28 PM   #11
soundman98
soundman98's Avatar
you're right, it's 5.5 quarts. kept thinking that i only used part of a 5quart jug, but i used all of it plus a half...
Perrin Engine Oil Cooler ThaDonJsuan BRZ First-Gen (2012+) — General Topics 12 08-10-2022 05:52 PM
Perrin Engine Oil Cooler - oil changes ThaDonJsuan BRZ First-Gen (2012+) — General Topics 3 01-13-2022 04:23 PM
Engine oil cooler install/mounting GrandSport Engine, Exhaust, Transmission 22 11-04-2018 01:28 AM
Perrin Engine Oil Cooler Kit for sale Dot_jp Canada Classifieds 1 10-14-2016 09:21 AM
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 10:21 PM
