Old 08-08-2022, 03:19 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
Perrin Engine Oil Cooler
Hey all,
Amateur BRZ owner/track enthusiast here. I recently had a shop install the Perrin Engine Oil Cooler and they mentioned it takes a bit more oil now but oil changes should be the same. My question is, does anybody know how much more oil it takes and is there anything about changing the oil that is different now? Just want to make sure I let any mechanics know about it before they do any oil changes.
Thanks,
Jason.
ThaDonJsuan is offline   Reply With Quote
Old 08-08-2022, 05:54 PM   #2
KillerBMotorsport
KillerBMotorsport's Avatar
I know the EJ engine oil filters have a drain back valve and am 95% certain the FA oil filters do as well. What that means is you add the capacity of the lines and oil cooler core to the total capacity. Perring should be able to provide this info.
Another way of doing it, after you've added the normal full capacity, is start the car. Then turn it off. Check the oil The oil cooler and lines would now be full, and you can top off to the 'full' mark.
KillerBMotorsport is offline   Reply With Quote
Old 08-09-2022, 04:12 AM   #3
DarkSunrise
DarkSunrise's Avatar
It’s approximately 1 extra quart of oil. Nothing really different about oil changes. The oil cooler will retain oil between changes so no need to add extra oil. Follow Perrins instructions after installation (prime the engine to make sure oil is pumped through the cooler before starting the engine).
2022 BRZ Build
2013 FR-S Build
Old 08-09-2022, 08:30 AM   #4
KillerBMotorsport
You guys don't drain the oil cooler? 1 quart is a lot to just leave in there.
Any OEM car I've owned with a remote oil cooler includes draining the oil cooler as part of the oil change procedure.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Breezio (08-09-2022)
Old 08-09-2022, 10:23 AM   #5
DrinkenBRZ
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
Odd. I’ve never been instructed through literature or otherwise to drain my coolers on my other cars. Most held at least a liter in the cooler, some two plus. Was not deemed material to the overall capacity, though I’d disagree on my RX8s that would only drain about 50-60% of their capacity in a single oil change.
DrinkenBRZ is offline   Reply With Quote
Old 08-09-2022, 02:18 PM   #6
DarkSunrise
I don’t, but I also had short OCI’s, roughly 3000-3500 miles. I’m not sure there would be an easy way to drain the oil in the OC, nor was it recommended by the manufacturer. I did a UOA and it looked fine even with heavy canyon use and a few track days.
2022 BRZ Build
2013 FR-S Build
Old 08-09-2022, 02:20 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Nope. Always heard not to bother. 7500mi on oil changes(0-20 300V) with as many as 6 tracks days and UOA’s always look fine.
NoHaveMSG is online now   Reply With Quote
Old 08-09-2022, 02:31 PM   #8
KillerBMotorsport
Off. My C63 and GT500 both have the oil cooler drain as part of the procedure. My 2016 Police Interceptor (winter beater) just says to get the oil to operating temperature so the oil cooler can drain with the engine oil.
Makes me wonder if it depends on the location, Both AMG and Shelby have them in the lower grill.
With the filter up high on the BRZ, I'd expect it to hold all that oil. With EJs we'd just add an inline Tee and Ball Valve Drain so you could dump the oil cooler lines and heat exchanger easily. I'd still do that on the BRZ. It's only ~$20 and I'd rather not have ~20% of the old oil still in there.
Old 08-09-2022, 03:41 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
Interesting. I always thought it was a little odd to leave the used oil in the heat exchanger. I like this idea in theory. What are the real-world downsides?
1. cost (negligible)
2. more points of potential failure (not a huge concern if done right)
3. what else?
Why wouldn't someone do this? Is 20% old oil just not enough to have a real-world negative impact? I could see that argument, but it kind of just seems lazy to me at the same time. It's not like one intentionally leaves 20% old oil in when there isn't an aftermarket oil cooler added.
Old 08-10-2022, 03:11 AM   #10
DarkSunrise
3. what else?
For me, the bolded part above was my reason. As long as my UOAs were coming out clean, why bother? It's expending resources to solve a problem that doesn't exist.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
blsfrs (08-10-2022), NoHaveMSG (08-10-2022)
Old 08-10-2022, 10:47 AM   #11
Grady
Grady's Avatar
I Like the idea of draining the oil cooler but access is not feasible where I mounted mine. It is behind the AVO intercooler but in front of the radiator. I change the oil regularly anyway so the oil that is in the cooler is in good shape anyway. Every 3k miles, or After any 3 track days, or will not do a track day with more than 1k miles on the oil.
For those who want to drain the cooler the best way to do it is mount the cooler were one side is low, us a AN T and but a B nut cap on one side. If you are worried about the B nut then you can drill it and safety it.
Old 08-10-2022, 03:21 PM   #12
KillerBMotorsport
For now. I'd rather not see how that plays out over time. By your premise, you might as well go beyond recommended OCIs, or only change out 3 quarts, to save resources. If this were an LS engine or any other engine on the planet that had better rod bearing oiling, the risk would be pretty low, but we're talking about a Subaru engine that already has known lackluster rod oiling from the factory.
There's always about 1/2 quart in the engine at an oil change (with or without a cooler). Adding another quart or spent oil to that, at some point, I can't imagine that would be good over the long term as part of that oil is always going to be from previous change, and the change before that, and so on.
Interested to see how your UOAs look over time.
Old 08-10-2022, 05:52 PM   #13
DarkSunrise
I’ve since switched to a 2nd gen BRZ, but FWIW, I did around 35k miles, 30 track days, 80-100 canyon drives and ran an e85 tune after adding the oil cooler and everything was fine when I did a UOA at the tail end. As long as the UOAs are coming out clean (TBN is good, oil is testing within graded viscosity, and there are no excess wear metals), I don’t see how it could be a problem. This is just my opinion though, not trying to convince anyone to adopt my approach. Everyone should feel free to get their own UOAs and change out the oil in their coolers if that makes them more comfortable, it makes no difference to me 👍
Also just to be clear I’m not recommending anyone go past their recommended OCI, in fact as I stated earlier I was changing my oil at less than half the OEM recommended OCI, partly due to my usage case and partly from knowledge that the oil cooler was retaining some old oil. Ultimately I think a UOA is the only reliable way to judge remaining oil life, and absent that, then following the OEM recommendation is a good approach.
2022 BRZ Build
2013 FR-S Build
Perrin Engine Oil Cooler - oil changes ThaDonJsuan BRZ First-Gen (2012+) — General Topics 3 01-13-2022 04:23 PM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 11:16 PM
Perrin Engine Oil Cooler Kit for sale Dot_jp Canada Classifieds 1 10-14-2016 09:21 AM
FS: Vortech Supercharger, Perrin Oil Cooler, Perrin Overpipe MrTranxD Engine, Exhaust, Bolt-Ons 14 08-17-2016 12:20 PM
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 10:21 PM
