Old 10-01-2022, 04:06 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by 2020BRZtS View Post
Are they truly "off" or are they on "Auto"?
off i don't use auto.
Old 10-02-2022, 08:26 AM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Have you ever owned a Dino? My dogs are very excited to see anyone come home. I open the door as soon as I pull in the garage so they don't jump up on the door and scratch the paint. Then I shut off the car. To give it perspective the dogs are 80 and 174 lbs.
Yeah, their trained NOT to that.
Chocolate Lab, Golden Retriever, Boxer Mix.
The Following User Says Thank You to x808drifter For This Useful Post:
2020BRZtS (10-02-2022)
Old 10-03-2022, 07:36 PM   #17
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
I wonder if this is something @geraldjust can do with his TracBox...
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
Old 10-31-2022, 08:28 AM   #18
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by gpvecchi View Post
It's a chime that sounds when you have engine running, you open the driver's door, then you turn off the car.
I get a repetitive long beep until the door is closed.
What I do is that I reach for the door ajar switch and press it, which it then turns the beeping off.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Door Chime Question ericmpena BRZ First-Gen (2012+) — General Topics 23 05-10-2021 11:56 PM
Oil consumption? Please chime in OnTheFence Issues | Warranty | Recalls / TSB 48 10-01-2019 08:42 PM
Disable your seatbelt chime. DIY Natedawg Scion FR-S / Toyota 86 GT86 General Forum 31 01-12-2015 02:22 AM
Door Chime Question Ec1990 BRZ First-Gen (2012+) — General Topics 6 08-20-2014 11:13 PM
DIY - Auto up/down disable (and retain door open indicator) Imperius DIY (Do-It-Yourself) Guides 4 02-10-2014 03:17 AM
