Old 11-02-2013, 05:03 PM   #1
Imperius
Imperius's Avatar
Drives: Subaru BRZ
DIY - Auto up/down disable (and retain door open indicator)
If you want to disable windows Auto up/down function and retain door open indicator you need to cut 2 wires (one for each door)
see pictures attached
Imperius is offline   Reply With Quote
Old 11-04-2013, 03:22 AM   #2
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
NO CUTTING! Just pull the pin out of the harness. Jesus...
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following 3 Users Say Thank You to Acree For This Useful Post:
Hardrock4445 (11-06-2013), Imperius (11-04-2013), mfbmike (02-10-2014)
Old 02-10-2014, 01:02 AM   #3
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
bringing this back from the dead in case anyone searches and wants to do this. Doing this (I pulled the pin ) will kill the passenger side window and door lock controls.... I say passenger because that's the one I tested it on. will probably kill the buttons on the drivers side if you do it there too... but it does keep the windows from opening/closing and retains the door open/closed switch.
edit again.. this was on an FRS.. not sure if all the BRZ wiring is the same.
Old 02-10-2014, 01:49 AM   #4
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Why would one want to do this?
ericmpena is offline   Reply With Quote
Old 02-10-2014, 03:17 AM   #5
Target70
Target70's Avatar
I disabled mine because it was causing the window seal to wear out on the passenger side of the car like here: http://www.ft86club.com/forums/showthread.php?t=11682
If you don't keep your car clean it could cause issues with window scratches or tint scratches: http://www.ft86club.com/forums/showthread.php?t=55995 <-- this sucks because you have to fix it immediately or not use the car, because even if you don't use the windows, you still make the problem worse just by getting in and out of the car.
others want to keep the window from rolling up/down while waiting for window tint to set up, or window freezing up do to snow/ice.
As someone who keeps vehicles for extended periods of time (more than 10 years average) I just personally think that it will over use and cause premature failure of window motors/window tracks, combined with window seal wear, glass scratches, tint pealing/wear, I see no good reason for the windows to do this in the first place. The windows do not contact the body (on my car) when completely up and opening/closing the door, and it properly seats into the pocket of the window seal. The only reason for this "feature" that I can find, is to alleviate cabin pressurization when closing the doors, so you don't have to slam the door to get it to latch.(which I don't have to anyway with the windows up) (*note that your door and glass are adjustable, and they could be aligned higher than mine, so if you do disable the window indexing, check to make sure yours do not hit before shutting the door)... (my passenger side is much closer than my drivers side)
Door Open Switch Raz BRZ First-Gen (2012+) — General Topics 7 04-10-2022 05:07 PM
Windows no longer open/close when door opened NOHOME Issues | Warranty | Recalls / TSB 13 04-18-2014 11:13 PM
DIY - Auto up/down disable (alternate method) PineappleFriedRice DIY (Do-It-Yourself) Guides 3 10-30-2013 12:08 PM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-11-2013 11:43 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
