Old 06-24-2014, 01:04 AM   #1
Ec1990
Drives: '14 BRZ
Door Chime Question
So I've searched and can't find the situation I'm in.
The door chime that usually occurs if you open the door before shutting the engine off is happening in reverse order.
Anytime I open the door after unlocking it it beeps until I close the driver's door, and same thing once I shut the car off until the driver's door is closed again the door chime goes on. Started happening after I got it tinted.
Any suggestions?
Ec1990 is offline   Reply With Quote
Old 06-24-2014, 02:17 AM   #2
irucremmi
Drives:
Did the tint shop guys or you disabled auto up/down when door is closed/opened, maybe that's what causing the chime?
irucremmi is offline   Reply With Quote
Old 06-24-2014, 02:59 AM   #3
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I thought that was normal?
Dr. BRZ is offline   Reply With Quote
Old 06-24-2014, 03:06 AM   #4
irucremmi
Drives:
If you shut off the engine and then open the door, it shouldn't chime... At least my doesn't unless you do it in reverse order , open the door and then shut the engine.
Old 06-24-2014, 10:11 AM   #5
Ec1990
Drives: '14 BRZ
Nope the windows still index properly, I'll double check the sensor. But agreed the door should only chime if you open it before shutting the engine down. Mine is chiming when I unlock it and open the door before starting the car and after I shut down the car and then open the door it chimes until I close the door.
Old 06-24-2014, 10:36 AM   #6
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Pretty sure mine does this and has since I bought it a couple weeks ago. I wondered if it was the cars way of telling you the fob was still in the car.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 08-20-2014, 11:13 PM   #7
Ec1990
Drives: '14 BRZ
Just to close this out, it was due to what I thought, the body control unit had failed. Replaced and it's fixed.
Door Chime Question ericmpena BRZ First-Gen (2012+) — General Topics 23 05-10-2021 11:56 PM
Door opening question TONYpepperon1 Electronics | Audio | NAV | Infotainment 6 03-15-2016 01:56 AM
Door speaker question BlackyRose Electronics | Audio | NAV | Infotainment 2 07-26-2013 10:45 PM
Height question for mt owners. At people can chime in too bdanisi Scion FR-S / Toyota 86 GT86 General Forum 17 03-07-2013 11:49 PM
Question on 2 door seats fitcious Scion FR-S / Toyota 86 GT86 General Forum 35 02-27-2013 01:11 PM
