Old 09-20-2022, 10:28 AM   #1
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
SSC Koni yellows with TRD springs
So I have an opportunity to get my hands on ssc koni yellows with trd springs when I told a trusted autox/track buddy of mine he said they are worst then oem in terms of how they ride on the street....
He was not sure if that was due to the eibach springs or not.... Being that this is NOT going to be a class build or a car used for competition but a street car that will see some track days road comfort is important.
So for the people that have experience with this combo please let me know how it rides on the street and what bump stops if any are you running thanks
autoracer86 is offline   Reply With Quote
Old 09-20-2022, 11:28 AM   #2
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
In North America the TRD springs are Eibach Pro-Kit springs... The same as SSC
Changing the bumpstops for something better would be good, the SSC kit rides too low because of the springs and is all over the really stiff bumpstops so it rides poorly.
Old 09-20-2022, 11:37 AM   #3
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I picked up a used set of Koni Yellows with TRD springs recently, and the previous owner's feedback was that with the damping set around 50% front and rear, the ride on the road was as good as stock, and he tracked them with the damping turned up to about 75%.
I have not installed them yet, so can't give my own feedback on how the combo works on the BRZ (and I'll actually be installing them with my H&R Sport springs instead of the TRD's, which are rebadged Eibach Pro-Kit's).
I had Koni's with H&R Sport springs on my previous car, and my experience was similar to the seller's, but being on a different platform, I wouldn't use that as feedback on how they will be on the BRZ/FRS/86.
I can say, however, that comparing my previous car on the Koni/H&R combo with damping set to the lower end of the range (about 25% front and 50% rear) vs. my BRZ on the stock Performance Pack suspension, the ride over smaller road imperfections was definitely better on my old car equipped with Koni's. The BRZ felt "busier" for sure. On larger impacts, however, the stock PP BRZ was better.
Again, though, different platforms, so not the direct comparison you're looking for...
Tatsu333 is offline   Reply With Quote
Old 09-20-2022, 11:51 AM   #4
autoracer86
Drives: Toyota GT86
Ah I didn't know the springs were the same. Thanks for that info guys.
Old 09-27-2022, 08:53 PM   #5
lonborghini
lonborghini's Avatar
Drives: '15 red FR-S SSC
I daily an SSC. Dampers on full soft for what is mostly a highway commute. What is this "ride" you speak of?
lonborghini is offline   Reply With Quote
Old 09-28-2022, 11:38 AM   #6
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I did some research before purchasing my 2017 BRZ. I was torn between getting a 2013-16 and leaving my options open to go SSC with the kit, or STX long term. One of the things I found was the SSC kit is quick for autox purposes, but ride suffers with the pairings of the Koni's and Eibach springs.
The difference in lowering with a coilover vs springs is you can usually get a the proper travel out of a coilover setup by adjusting the body vs lowing where the car sits on the strut via the spring in a traditional spring/strut setup.
The valving you get out of a better $1500+ coilover setup is likely better than the Koni + Eibach pairing too.
IMO, if you're going for a street car with some limited track time, the RCE Super Street-1 is a good option. Second would be something like RCE yellows on Sachs PP struts, which people have had good luck with. I always see the SSC cars at events sitting very low in comparison to even one with RCE Yellows.
cmiovino is offline   Reply With Quote
Old 09-28-2022, 12:42 PM   #7
autoracer86
Drives: Toyota GT86
What springs are you running ?
Old 09-28-2022, 12:45 PM   #8
autoracer86
Drives: Toyota GT86
I was thinking of getting the RCE yellows and bilstien b6s but I can get this koni/trd combo from a friend.
I am starting to think I might just use the koni yellows with stock springs and upgrade to coils later on. This car is just being used for HPDE fun so lap times are not super important
Old 09-28-2022, 01:11 PM   #9
cmiovino
cmiovino's Avatar
This is a good option. The struts are going to make a big difference over stock, especially if yours are worn out. Plenty of people use the stock springs with Konis for street class autocross. Stock springs will give you proper travel, so the ride will be good. Likely better than stock even.
Old 09-28-2022, 01:15 PM   #10
autoracer86
Drives: Toyota GT86
Cool ! I think I will go with that then
Koni adjustable Yellows set and TRD springs bmacfrs Brakes, Suspension, Chassis 6 11-12-2019 11:49 PM
WTB: RCE Yellow springs, Koni Yellows, Blistein B6 ermagawd Canada Classifieds 0 07-14-2017 11:33 AM
Koni Yellows + Eibach Springs [OH] RavioliG Brakes, Suspension, Chassis 4 01-14-2017 08:07 PM
Koni Yellows with TRD lowering springs morrisonmagic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2016 04:36 PM
