Old 11-09-2019, 11:28 AM   #1
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Koni adjustable Yellows set and TRD springs
Koni sport yellow adjustable shock/strut complete set. Including the TRD lowering spring set (PTR07-18130). Lowers car 1-1/8 inch. You also get the Whiteline camber bolt kit. All this as new parts would be over a grand.
All parts are used with about 20k miles. Nothing wrong with them. The fronts come with the stock top hats on so they are ready to install. These fit all model years for FRS/BRZ/86.
$400 plus shipping.
WIFE: "How can there be anything left to buy?"
bmacfrs is offline
Old 11-09-2019, 03:08 PM   #2
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Great deal for some good struts and springs.
-B
HeresMyMind is offline
Old 11-09-2019, 06:44 PM   #3
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
1 1/8 sounds like the perfect drop for struts and springs. GLWS
Will BRZ is offline
Old 11-10-2019, 10:15 AM   #4
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I recently installed this set-up with Peddars -.75*offset top mounts and double camber bolts.
Although I haven’t played with the adjustments much yet, the ride quality during DD is improved over the OEM dampers when set at ~25% firmness.
Can’t wait for spring to get out on track and crank up the damping.
Muskoka800 is offline
Old 11-12-2019, 11:07 PM   #5
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
SOLD
Sent from my SM-G960U using Tapatalk
bmacfrs is offline
Old 11-12-2019, 11:17 PM   #6
xchen70
Bump! Good seller. I am the buyer lol
xchen70 is offline
Old 11-12-2019, 11:49 PM   #7
Will BRZ
Drives: 2015 BRZ
Congratulations lol Used struts and springs seems like a great alternative to coilovers if you don’t want to spend too much
Will BRZ is offline
Custom suspension setup - Koni Yellows and Tein H-Tech springs KVDB31 Brakes, Suspension, Chassis 5 11-30-2018 03:31 AM
WTB: RCE Yellow springs, Koni Yellows, Blistein B6 ermagawd Canada Classifieds 0 07-14-2017 11:33 AM
Koni Yellows + Eibach Springs [OH] RavioliG Brakes, Suspension, Chassis 4 01-14-2017 08:07 PM
Koni Yellows with TRD lowering springs morrisonmagic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2016 04:36 PM
