Old 09-07-2022, 11:37 AM   #85
Angrypuppy
Drives: 2022 BRZ Limited on order
So I mulled this over last night. Do I live with this quirk or move on to another platform. Not a huge deal, but big enough issue I’m reconsidering my choice of the BRZ. Need new rotors and don’t want to sink a bunch of money into this thing if I’m going to pull the plug.
Has anyone taken it into a dealer for “warranty” work. The used market is still strong enough it would be easy to jump ship.
Curious what other 22’ owners are planning or trying.
Angrypuppy is offline   Reply With Quote
Old 09-07-2022, 11:41 AM   #86
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Angrypuppy View Post
It happened one other spot, I can’t recall exactly where. I think 12. For sure not 2,5, or 6 though. Strange. 2-3 times in 8 and once somewhere else, probably 12. 5 20 minute sessions.
Maybe the thumb, t11? 12 has that change in grade part way through. I can see T8 causing it, my car just doesn't hook up there so it doesn't happen to me there.
Probably just a combination of heat, and how hard you were working the car.
Old 09-07-2022, 12:03 PM   #87
ML
ML's Avatar
Drives: 13 White MT FR-S
wait so you had this happen on a 2nd gen 86?
Old 09-07-2022, 01:40 PM   #88
RedReplicant
Drives: None
Yay, happened to me today for the first time. Out at The Ridge in WA, turn 8.
For others that have experienced this, does it get worse or more frequent. Today was annoying. But I could live with it if this is all that I get.
The more grip the car makes (or as you get quicker) the more frequent it becomes
Interference between the chassis and sway bar endlink, chassis and sway bar, endlink binding, etc can also cause it but I've already fixed all of that.
A few other second gens also posted about it in the other thread, unfortunately
RedReplicant is offline   Reply With Quote
Old 09-07-2022, 02:30 PM   #89
Angrypuppy
Correct
Old 09-07-2022, 02:31 PM   #90
Angrypuppy
I agree, 2:01:07 yesterday. Previously 2:02-2:03. New best for me and starting to push harder.
Old 09-07-2022, 04:36 PM   #91
CSG Mike
CSG Mike's Avatar
What other platforms would you consider?
Old 09-07-2022, 05:11 PM   #92
Angrypuppy
Rush Autworks SR1
Porsche 981 S/GTS
Possibly a new Supra
Old 09-10-2022, 07:16 PM   #93
eb66
Drives: 2015 FRS
Originally Posted by RedReplicant View Post
I messaged with them a bit and they said they haven't had any reports of cut out. I'm somewhat skeptical but maybe?
Yes, that is the one. I got the one where you set the assist where you want it with the button, and it gives a consistent level of assist.
eb66 is offline   Reply With Quote
The Following User Says Thank You to eb66 For This Useful Post:
RedReplicant (09-11-2022)
Old 10-12-2022, 11:58 PM   #94
zoomswimmer
Drives: 2013 FR-S, 1986 AE86
You can muscle past it, but you can fix it by correcting your suspension geometry in the front.
Will Rob be driving your car at SLB this year?
What suspension geometry differences would you recommend? More Caster?
zoomswimmer is offline   Reply With Quote
Old 10-13-2022, 12:36 PM   #95
RedReplicant
Drives: None
I would expect more caster to make it worse.
I'm also curious what suspension geometry changes are supposed to solve this.
I swapped from JRZs to Shaftworks last week, absolutely verified that there is no binding in the bar endlinks, zero contact anywhere, etc. The cutout is still there.
The car only sees about 1.3-1.4g lateral, it doesn't happen during laps that are a couple seconds off pace.
The Following User Says Thank You to RedReplicant For This Useful Post:
DocWalt (10-14-2022)
Old 10-14-2022, 02:00 PM   #96
RedReplicant
Drives: None
So, funny story, I was helping Vorshlag set the M3 CSL parameter on their MK60 ABS yesterday and I happened across this picture that he posted.
Might be worth a shot.
gt5759 (10-14-2022)
Old 10-14-2022, 02:15 PM   #97
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Upgrading to Nvidia 4090 may really be worth it, but then you're too heavy for the class?
RedReplicant (10-14-2022)
Old 10-14-2022, 02:48 PM   #98
RedReplicant
Drives: None
LOL
rattling when braking Latiii Issues | Warranty | Recalls / TSB 14 08-07-2014 01:16 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 05:52 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 02:19 AM
Braking Issue In Mid Drift imravenit Tracking / Autocross / HPDE / Drifting 12 02-12-2013 04:16 AM
