Old 08-07-2022, 04:20 PM   #1
jflogerzi
jflogerzi's Avatar
Dedicated Track Without Cage
As I embark down this journey, I have a question? For this season I plan to run a proper Racing Seat, harness bar, and 5 point harness with Anti Submarine support and a Hans device. This car is no longer street driven and will be trailered to all events. Is it advisable to leave Airbags in or remove with this setup. I plan to get a cage at some point in the future just not this season. This car is being used in HPDE's only and not any sanctioned events.
This aspect of Racing is completely new to me.
2013 Series 10 FRS #553
Old 08-07-2022, 04:59 PM   #2
norcalpb
norcalpb's Avatar
Stock safety equipment imo until you get a cage. If you roll your car and your roof collapses, that HANS device may prevent your neck from bending and bad things may happen.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
DrinkenBRZ (08-07-2022), Icecreamtruk (08-13-2022), jflogerzi (08-07-2022)
Old 08-07-2022, 10:15 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
If he rolls his car he will probably have an impact hard enough to benefit from the HANS, too.
Old 08-07-2022, 10:32 PM   #4
SCFD
Why not just run the factory seats and safety equipment? Once you get a seat and harness I'd want to get a roll bar at a minimum.
SCFD is offline   Reply With Quote
Old 08-07-2022, 11:18 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Opinions vary, but for me the moment a 5/6 point harness goes in the car it's time for a roll hoop.
The roll hoop (otherwise called a half cage) can prevent spine compression in the event of a roll-over and the roof comes down over you. With a multipoint harness, your body has nowhere to go. In a stock or close to factory configuration with 3point seat belt, there is still enough flex room for your body to move downward since there isn't the leg loop keeping you constrained. The factory seatbelt pretensioner system keeps you from submarining
If you ever elect to go for a full cage, the car will not likely safe for street use anymore as the structures goes over the front door frame. You risk head impacts in street conditions because you won't have a helmet on
EndlessAzure is offline   Reply With Quote
The Following 4 Users Say Thank You to EndlessAzure For This Useful Post:
Icecreamtruk (08-13-2022), MrSkubi (08-18-2022), RT-BRZ (08-08-2022), villainous_frx (08-08-2022)
Old 08-08-2022, 12:50 AM   #6
jflogerzi
jflogerzi's Avatar
Thank you for comments. Mainly I want to remove as much weight. Car will not be driven on any public roads. Strictly for HPDE. But this has given me things to research.
Old 08-08-2022, 01:35 AM   #7
jflogerzi
jflogerzi's Avatar
New Question.
I have decided to not use a harness or Bar but the OEM 3 point. With this and the HANs would it be advisable to use stock airbag in the searing wheel?
Old 08-08-2022, 01:52 AM   #8
EndlessAzure
Wheels for Brains
I would say, exercise caution when trading safety and weight savings.
New Question.
I'm not as well read on this part, but my impression is that the factory 3 point system is intended to be used with the airbag. If you swap to an aftermarket steering wheel without airbag, it would not be advisable to use on the street since you risk head impact to the wheel. When you're on track with a helmet, maybe it's passable?
With regard to frontal head restraints, it can be used along side the airbag. Not every collision will trigger the airbag, but the sudden deceleration of your head PLUS the weight of the helmet can cause serious injury even at low speed. That being said, the only type of FHR that I am aware of that are marketed as 3-point compatible is the Simpson Hybird line, which isn't technically a traditional HANS that requires harness over-shoulder belts.
The Following User Says Thank You to EndlessAzure For This Useful Post:
jflogerzi (08-08-2022)
Old 08-08-2022, 05:31 AM   #9
SCFD
In my opinion, this sounds like overkill for anything short of a race car. A simple way to reduce weight without affecting any of your safety equipment would just be to remove the passenger seat and rear seats.
Even as a dedicated track car that gets towed to events, parts failures can really ruin your day so I'd focus on being able to run the car for extended periods reliably. Have you looked into things like oil coolers, track pads, brake ducts, and fire extinguishers?
I currently have limited seat time in this car but in terms of safety equipment, I plan on going with a Simpson Hybrid Sport (3 point compatible Hans).
Old 08-08-2022, 03:14 PM   #10
ka-t_240
Make sure to look into what your event organizers allow, more and more I see restrictions on organizers not allowing fixed back seats/harnesses with out at least a roll bar.
ka-t_240 is offline   Reply With Quote
Old 08-08-2022, 03:20 PM   #11
fminicooper
Drives: FRS Hot Lava
IMO
Stock seat with Schroth Rallye 4 (ASM technology and the ability to install the belts to stock harness mounting locations)
Hans (Hybrid is posible)
Just my two cents. As samebody was saying, opinions vary.
Welcome to the track.
Do no fix what is not broken, change brake fluid.
fminicooper is offline   Reply With Quote
Old 08-08-2022, 03:36 PM   #12
norcalpb
norcalpb's Avatar
New Question.
That should be fine to still run the airbag but definitely don’t crack your visor on your helmet. If the airbag goes off and hits your visor, it can knock your head back pretty far up and back.
Old 08-08-2022, 05:35 PM   #13
CSG Mike
CSG Mike's Avatar
You can break this down into 2 stages
1.
Hybrid S + best helmet you can afford
Optional: full fire gear
2.
Full cage + seat + harnesses
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
finch1750 (01-29-2023), Icecreamtruk (08-13-2022), Ohio Enthusiast (08-08-2022)
Old 08-08-2022, 11:27 PM   #14
jflogerzi
jflogerzi's Avatar
Just strip the interior minus safety systems and use stock seat and 3 point for now. Next stage will be roll cage, seat, etc... BTW not new to tracking my FRS and I have the car pretty dialed in
Sent from my Pixel 6 using Tapatalk
FEELER : track FRS gutted full cage philooo Cars for Sale/Trade 9 05-23-2015 03:32 PM
Dedicated Track/Race Suspension Iwannajag Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-05-2015 03:47 PM
FS/FT 03 350z Track - Low Miles - CA car - Roll Cage sanbaifo Cars for Sale/Trade 0 03-27-2014 08:15 PM
Auto Power full cage photos? Custom cage prices? Anthony Tracking / Autocross / HPDE / Drifting 4 08-08-2013 11:52 AM
what if you dedicated $2,000 brichard0625 Engine, Exhaust, Transmission 28 04-07-2013 01:13 AM
