Old 08-02-2012, 12:50 AM   #1
white86
Drives: Whiteout FRS
Coilover Clunk (Brand new)
Ok so I just installed my coilovers (not going to say which brand for fear this may just be a bad one and I dont want to slander their brand). Anyways I just installed them and I got this wicked clunking noise in the rear right mount. They are pillow ball rears and I tried using an impact gun on the upper shaft bolt but it didnt seem to change anything. Ive fully removed the coilover and inspected it for play and leaks but it seems 100% fine. Could this be something other than the pillowball mount making this noise?
[ame="http://www.youtube.com/watch?v=hf0OMGdrMCs&feature=plcp"]Gt86 coilover clunk - YouTube[/ame]
white86 is offline   Reply With Quote
Old 08-02-2012, 12:53 AM   #2
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
I had this noise on the BC coilovers I had on my old car. It always did that, I hated it do much.
Asphaltfrs1 is offline   Reply With Quote
Old 08-02-2012, 12:55 AM   #3
epson1
Drives: 2013 BRZ Limited
I'm going to take a shot in the dark and guess you paid less than 1000$ dollars for said coil overs
epson1 is offline   Reply With Quote
Old 08-02-2012, 12:56 AM   #4
white86
It only seems to be coming from one side though, so obviously somethings wrong with it
Old 08-02-2012, 01:10 AM   #5
white86
And list on them is over 2k
Old 08-02-2012, 03:20 AM   #6
blags
Drives: Toyota 86
Lol at the immediate assumption that they're under 1k
blags is offline   Reply With Quote
The Following User Says Thank You to blags For This Useful Post:
dabocx (08-02-2012)
Old 08-02-2012, 04:13 PM   #7
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
White86: Contact the manufacturer. If it's new, they should be able to offer you a replacement pillow bearing. Should do the trick.
Epson1: Wouldn't be to quick to jump to conclusions. We've had an Evo X in here with Ohlins DFV's with both front and rear pillow ball bearings that clunked louder then that.
It's even a common issue with Evo X front OEM upper mounts which are spherical bearing with rubber bushing around it.
Pillow ball bearings sometimes go bad. They are a wear and tear item.
The tolerances on the bearings are so tight then even a .1mm wear can lead to a loud clunk in a car.
Touge Factory is offline   Reply With Quote
The Following 2 Users Say Thank You to Touge Factory For This Useful Post:
hmong337 (02-25-2015), TylerLieberman (04-09-2014)
Old 08-02-2012, 07:41 PM   #8
white86
Thanks, ya the manufacturer already said they would replace it. I'm gonna disassemble the top mount tonight and see what's up. Yea they're expensive coils but that doesn't really mean anything. I realize not everything can be perfect and shit happens and slips through the cracks. That's why this is a throwaway account because I want to give the manufacturer the benefit of the doubt
Old 08-02-2012, 08:18 PM   #9
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
they warned us about upsetting the balance of this vehicle...jkjk
driftartist is offline   Reply With Quote
The Following User Says Thank You to driftartist For This Useful Post:
jumbaco (04-16-2013)
Old 08-02-2012, 08:30 PM   #10
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
And then Tada encouraged us to modify it.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 08-02-2012, 09:59 PM   #11
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Do these have a helper spring on them? If not, did you check to make sure the pre-load was good on that one damper? It sounds like an upper mount to me, but trying to think of what else it may be.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-02-2012, 10:10 PM   #12
Rurounimidnight
Rurounimidnight's Avatar
Drives: Past S13 S14 350Z, Future FRS
Def bad pillowball, replace and should do the trick goodluck.
Rurounimidnight is offline   Reply With Quote
Old 08-02-2012, 11:12 PM   #13
Don@Accelerated
Don@Accelerated's Avatar
Did you remove the lower sway bar end link bolt from the control arm?
Don@Accelerated is offline   Reply With Quote
Old 08-02-2012, 11:16 PM   #14
Don@Accelerated
Thats because they are crap. I've installed a few of those and you need to put a ton of preload in the spring itself on the body. But that makes it ride like garbage.
Clunk when going into first gear? huma BRZ First-Gen (2012+) — General Topics 22 07-24-2014 06:49 PM
DG-5 Coilover harajukukei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-27-2014 04:42 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 01:10 AM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 12:43 PM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 08:08 PM
