| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#365 | |
The blocked passage is indeed obvious and in your face. That does not automatically make it the whole issue. We don't know what Subaru is doing about warranty at this point. AGAIN not enough data to say. They may go the same route as Toyota and blame "abuse". There are really two different subjects here. One is the fact that there is an obvious problem with the oil system of the engine. The other is how they are reacting to that issue for warranty.
#366 |
Drives: frs
https://www.motortrend.com/news/toyo...drifting-pics/
First R&T, now Motortrend. I imagine C&D will be next up? |
#367 |
Actually the small chunks that you can't even see may be a bigger concern than all that gunk in the pictures. A small piece introduced to the oil passages anywhere after the filter (and yes it can happen as the whole engine is put together with that goop) will do more damage much faster than a partially blocked pickup. The 2013 issue was almost always a blocked oil channel which took out one bearing. The pickups may have had a little in them but they were not the bigger problem.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (08-03-2022) |
#368 | |
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#369 | |
Drives: 2021 Supra / 2022 Tundra
TomR
#370 |
Drives: 2020 GMC Canyon Denali Diesel
DocWalt & ABQautoxer....have your engines failed? If not, what are you having "fixed" before you sell?
From what I have seen there have been less than 10 reported failures in the US currently between both models....that's a pretty small percentage. (I'll get the true number of Subaru failures later today...still bet it is a small number).
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | Petah78 (08-03-2022) |
#371 |
Drives: '12 C63 P31, '23 GRC
I'd caution people to take it easy with the fear mongering. You're being a bit ridiculous (IMO) and the only way you're gonna ease your fear is switching to some cheap ass old car with cheap engines (for when you pop one).
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following 4 Users Say Thank You to WolfpackS2k For This Useful Post: |
#372 |
Drives: 22 BRZ
GRM taking a more measured approach with some key extra info I hadn't seen yet about the dealership involved - https://grassrootsmotorsports.com/ne...ngine-failure/
#373 |
Drives: 2022 BRZ sport-tech
That would be awesome if you can. I am assuming you have some sort of Suby hook up?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#374 | |
#375 | |
Drives: '22 BRZ
I posted video way back in the thread of the ridiculous quantities of excess RTV hanging off of my oil pan interface. When that breaks off (and it will) it will clog the pickup. buttttt my comment was specifically about this: Subaru/Toyota are going to need to issue a recall/TSB to take the oil pan and timing cover off and remove the excess sealant and put it back together with the appropriate quantity. If during that process they find substantial quantities already on the oil pickup, I'd just sell the car. I'm not taking on the risk of having my engine blow up in six months or six years because the bearings maybe sustained damage. I don't really understand what's so hard to understand about this.
#376 |
He does.
#377 | |
Drives: Crapcan
#378 |
Drives: 22 BRZ
My $0.02 - it's not a big deal for me personally to remedy the issue myself so I'm really not freaking out about it, but I get why it's a big concern for most. I'll be pulling my pan when I do my next oil change, cleaning things out, and resealing it correctly. Not going to bother with the timing cover because I assume most of the excess sealant will have already shed off. Might pull the pan again sometime next year to double-check for any more scraps. I'd much rather be proactive than wait for something catastrophic go wrong, have to interact with a dealer, and be without the car for an extended period of time.
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
