Old 08-01-2012, 11:38 AM   #1
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
MAX Spacer thickness for stock studs?
Hey guys, let me first let you know WHY I'm asking this. I am looking at a set of used OZ Superleggera's that are perfect, with tires, except that they are an ET60 offset. From my initial searching, I don't think that we have the thread length to fit 12mm of spacer.
Can anyone tell me what the maximum spacer thickness is that will fit, with FULL thread engagement between the nuts and studs?
Thanks
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 08-01-2012, 12:39 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
3mm. If you want to run those wheels, upgrade to a set of lengthened and hardened studs.
Old 08-01-2012, 12:41 PM   #3
Eric@GetYourWheels
Drives: 2013 Porsche Boxster S
At 12mm you should just go for a 15mm spacer and get a ichiba spacer that bolts to the car and then the wheel bolts to the spacer.
Eric@GetYourWheels is offline   Reply With Quote
Old 08-01-2012, 12:48 PM   #4
empower-auto
Kouki-Monster
empower-auto's Avatar
Use a Project KICS or H&R Trak+ spacer kit instead of Ichiba. Ichiba stuff is mediocre quality and the hardware they use is junk.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-01-2012, 12:50 PM   #5
Eric@GetYourWheels
I would first recommend getting a wheel that fits without spacers. That being said we have used ichiba with no issues however Project Kicks and h&R are also great options.
Old 08-01-2012, 10:42 PM   #6
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
I would bet that the "bolt-on" spacers are much weaker than slip on spacers. Especially at 15mm. There is not a whole lot of material holding that spacer to the hub... not to mention it's aluminum.
My advice? Save up for some wheels in 17x8 +35 and wrap the stock tires on them, if your trying to save a little money.
Entropy is offline   Reply With Quote
Old 08-01-2012, 11:19 PM   #7
ed209
Drives: '12 Mustang GT
Thanks
just buy proper wheels for your car, it will serve you much better in the long run than half-assing it to save a few bucks.
ed209 is offline   Reply With Quote
Old 08-01-2012, 11:52 PM   #8
epson1
Drives: 2013 BRZ Limited
You must be high, or have never seen a spacer before.. I've ran 5mm up to 30mm on the front of my 240sx to clear different wheels and I've never broke anything. Personally a 60mm offset is huuggee and not recommend but go for it and get some bolt on spacers.
epson1 is offline   Reply With Quote
Old 08-02-2012, 12:05 AM   #9
FRSpdDmn
The thing I don't like about the bolt-on spacers is that you're then threading into aluminum. That just spells trouble to me, especially for track duty. The tires on these wheels are 235/40/17 Toyo RA-1's.
Thanks for the responses, folks. I think I'll have to pass, even though they're a great deal. I'll probably wait to get the right wheels.
-Anthony
Old 08-02-2012, 12:57 AM   #10
Entropy
Entropy's Avatar
Drives: GT86
Agree to disagree, but I'd rather have the studs that are holding on my wheels be pressed into a steel hub, not some cheapo aluminum jobby.
I know that many people, yourself included, have never had problems with them. There are also those that have. In my opinion, such a "mission-critical" part shouldn't be cheaped-out on. Cheap-out on an exhaust or intake, but not on what is keeping you from ending up flipped over in a ditch.
Wise choice. Remember what your parents said, "do it right the first time or don't do it at all..."
Old 08-02-2012, 02:05 AM   #11
epson1
I've ran 225/40/18 nitto nt05s ALL SEASON on my formula D car and have had zero problems and I know of about 15 professional drivers who do the same. But your money. I wouldn't buy the wheels just cause of the goofy offset. I'm defending spacers is all.
Old 01-31-2013, 11:08 PM   #12
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Sorry for the old thread revival....didnt wanna create yet another thread on this.
So what you're saying is that even a 5mm slip on spacer like this would mean that the nuts would not be fully threaded onto the factory studs by 2mm?
http://www.ebay.com/itm/Subaru-IMPRE...item5ae4be1038
Fizz is offline   Reply With Quote
Old 01-31-2013, 11:10 PM   #13
OrbitalEllipses
Drives: Attitude
5mm spacers should come with studs, for the reason that the stock ones are too short. Eibach 5mm spacer has always come with studs as have the other good names.
Old 03-04-2015, 10:34 AM   #14
Synack
Boosted
Synack's Avatar
Drives: Sideways
Reviving this bad boy again. Are we CONFIRMED that 3mm will be just fine? I do take my car out on mountain runs a lot.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Stock FR-S amp sirhc Electronics | Audio | NAV | Infotainment 36 01-18-2014 08:38 AM
Spacer how to right in your driveway. F3dzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 10-22-2013 07:31 PM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
