Old 08-01-2012, 10:07 PM   #29
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by Username View Post
So I have noticed that hot are comes thru the vents that blow toward your face when using outside air and no AC.
I had to switch to my windshield vents really quick, and when I switched the vent back to the forward facing vents again the air was ice cold for only a moment.
I hadn't turned on the AC or turned on the air recirc, all I did was change what vents were blowing. I just can't figure this thing out.
The reason why it is ice cold when switched to "windshield" and back is because, in "windshield" mode it actually uses the AC to defog your front windows quicker (AC button does not light up in these situations)...Standard safety feature.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
Username (08-01-2012)
Old 08-01-2012, 10:09 PM   #30
Saber_TRD
Saber_TRD's Avatar
Drives: '09 Cobalt SS Turbo
My Celica has this "issue" although I don't consider it a problem. It's more noticeable after a few lift spirts (engaging lift at 6200rpm and holding till the ~8000rpm red line, shift, and repeat till 3rd or 4th gear, depending on location. The 2ZZ-GE was meant for this.)
In other words, as the engine warms up the warmer the air from the vents is. I've always figured the vents get their air from the engine bay or close to it. As mentioned before, switch to recirculate and it should go away/reduce. Turning on A/C also overpowers it.
Otherwise, if you're too lazy to turn on the heat when it's needed, simply hit the throttle lol
Saber_TRD is offline   Reply With Quote
Old 08-01-2012, 10:38 PM   #31
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Heater core. My XRS did something similar.
CircuitJerk is offline   Reply With Quote
Old 08-01-2012, 11:35 PM   #32
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Hey too bad our little wing windows don't pivot like cars from the 60s. lol
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 08-02-2012, 10:06 AM   #33
FRiSson
Drives: FR-S MT
YES!. Maybe someone will come out with a "vent window" conversion kit for those little triangles of glass in the door.
FRiSson is offline   Reply With Quote
"vent" setting very warm to hot MTeator Scion FR-S / Toyota 86 GT86 General Forum 39 02-12-2023 09:35 AM
question about brz/fr-s front fender vents nmullin11 Cosmetic Modification (Interior/Exterior/Lighting) 23 03-20-2013 05:01 AM
Warm vs cool Weather performance EsoBOFH Scion FR-S / Toyota 86 GT86 General Forum 22 07-10-2012 11:45 AM
Does anyone know Part Number for side Vents?? stevo_12v Cosmetic Modification (Interior/Exterior/Lighting) 2 05-16-2012 10:30 AM
Fender Vents real or fake KaliKev Scion FR-S / Toyota 86 GT86 General Forum 48 12-03-2011 01:24 PM
