Old 06-27-2022, 11:28 PM   #85
hguerrero
Drives: Scion FR-S
Originally Posted by geraldjust View Post
Looks like the immobilizer antenna ring. So it goes on the plastic that goes around the keyhole. You should see a connector towards the backside of it.
It was actually an ignition switch, car wouldn’t turn on without it plugged. It wraps around the steering wheel and the connection is on top of the ignition.
Rattle problem solved!!!!
hguerrero is offline   Reply With Quote
Old 07-22-2022, 03:44 PM   #86
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Anyone know if there is any reason NOT to make a replacement piece out of aluminum so that I don't need to worry about taking it apart again later on down the road? Or do we know for a fact that the Hyundai one is more durable and won't have the same issue? Also, WTF is the purpose of this part anyway? Is there a reason the two halves don't directly connect? Is this for NVH reduction or what?
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 07-22-2022, 05:10 PM   #87
This is a particular flavor of flexible coupling that must exist between the driving, and driven rotating subassemblies. It accommodates the misalignment between them. Sort of like a CV joint for small angles/offsets.
Old 07-23-2022, 02:35 AM   #88
geraldjust
Drives: MR2, Sliver BRZ
The only thing i can think of is that if vibrations can cause some induced isolation on the force sensor on the input shaft. Maybe, milled out of a harder plastic. I know the Hyundai bushing is made out of rubber though. So it will eventually break apart too. So very hard plastic needed or soft metal?
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 07-23-2022, 11:45 PM   #89
jto247
Drives: 2013 Brz
Thanks for the guide, it worked perfectly! That annoying rattle is finally gone.
jto247 is offline   Reply With Quote
Old 08-06-2022, 03:01 PM   #90
Stang70Fastback
A.K.A. Starlord
Apologies if this has already been stated, but I wanted to further add some information I hadn't seen mentioned:
OP provided the following link to the Hyundai part on Amazon: https://www.amazon.com/gp/product/B018WNMSBK
The part number it claims to replace is 563152K000FFF. That IS, as far as I'm aware, the proper part number. If you read some of the comments on that listing, you'll find this very informative comment:
Same OEM manufacturer as the original (TSR) rubber part but this new version is made of polyurethane. A technical service bulletin from Kia and and one from Hyundai indicate the letters HNBR molded onto the new version indicates it is made from polyurethane. There was also a previous "improved" version made of a more durable rubber marked with 4P from the same manufacturer, TSR. The original part has only the manufacturers name (TSR) and a number indicating the injection molding die cavity from which multiple parts were made at the same time. The newest polyurethane parts have superior durability and a higher durometer hardness so they are not as soft as the original. I just replaced my original, which was actually in perfect condition, with the polyurethane part. The steering is now noticeably more responsive with a tighter, less spongy feel when turning, changing lanes, or just normal subtle steering corrections while driving straight.
The photo in the Amazon listing shows HNBR, which according to that comment, should be the latest revision of the part, as per the Hyundai TSB. However, the part I received had 4P stamped on it, suggesting it was the initially revised part, but not the most durable second revision made of polyurethane.
So I went to the dealership, and asked for the same part number. The part number is indeed the same, but this one has HNBR stamped on it, and feels MARKEDLY difference. It's actually softer and more flexible than the interim part. This is odd because the info above says that it has a higher durometer hardness than the original, so I'm wondering if the "first revision" (4P) part somehow wildly overcompensated and went too hard, and maybe that caused its own issues, and so they backed off to the HNBR version, which is softer than the 4P, but harder than the original? It's all a bit confusing.
So I looked up the actual TSB: https://testing-public.carmd.com/Tsb...118786/5003566
In the TSB, it states:
Note: There are 2 versions of this part number:
1. “HNBR” marking on polyurethane part
2. “4P” marking on revised rubber part
Both parts are improved with increased durability,
and can be used for procedures in this TSB.
Now I'm wondering which to use! The stiffer one because in theory it'll provide better feedback... or the HNBR one because it seems to be the most recent revision, and theoretically might be the "best" to use? Ugh, decisions! (I'm leaning towards the HNBR one.)
I also want to point something else out that nobody seems to have mentioned, which is that this part does NOT fit quite as perfectly as a replacement as it sounds like it does. It does fit, but you have to force the motor back onto the assembly. That's because the center punch-out on the Hyundai part isn't as bit as the raised section in the steering shaft assembly, meaning the fins don't go all the way down and bottom out the way the factory part does. I guess everyone has just been forcing the two halves back together and calling it a day, but it's just not as perfect of a replacement part in terms of fitment as I had expected.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
MJones_RB (01-18-2023)
Old 08-08-2022, 10:42 AM   #91
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Arrow
The official Subaru SB is this: SB22-036, issued on April, 2022.
Repair Kit part no. is 34595CA000 and contains 1 Rubber Spring, 1 Spacer, and 2 tightening bolts for Power Steering Motor, estimated price 21/25$
About other noises to column there is the SB SB22-024-1 that well explain how to solve.
Trap63 is offline   Reply With Quote
The Following 6 Users Say Thank You to Trap63 For This Useful Post:
DocWalt (08-31-2022), ermax (05-03-2023), MJones_RB (01-18-2023), sato (01-09-2023), Ultramaroon (08-24-2022), whataboutbob (07-11-2023)
Old 08-08-2022, 01:53 PM   #92
Stang70Fastback
A.K.A. Starlord
I actually wound up putting the OEM part back in. I HATED how the Hyundai part didn't fit properly.
Old 08-24-2022, 10:02 PM   #93
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Good to know, wonder if this has been put out for Toyota as well?
Sent from my Pixel 6 Pro using Tapatalk
Rican_D is offline   Reply With Quote
Old 01-06-2023, 08:10 AM   #94
El Barto
Drives: Toyota 86 GTS
Cool Successful fix buttttt
Hi everyone,
Today I successfully replaced the EPS coupler and the rattle is gone. So what of an ordeal for me but super happy!!!! However, when I test drove I noticed the steering feel had changed in two ways:
1. Slightly but noticeably heavier
2. Steering wheel no longer goes back to centre. Ie a very slight turn to the right will keep that angle and not come back to centre.
What could have possibly gone wrong, what can I check?
Many many thanks!!
El Barto is offline   Reply With Quote
Old 01-09-2023, 05:17 PM   #95
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
That's.... weird.
When I did mine, the car was immediately back to "normal" behavior. I did get an EPS warning light, but I put that down to the car stalling and being re-started during a turn (my car stalls very easily for the first few miles after an ECU reset), it turned off after 5-10 seconds and never came back .
Steering feel and centering haven't changed a bit. I think you might either have placebo effect, or have done something wrong.
Good luck in finding the cause if that issue!
alex87f is online now   Reply With Quote
Old 01-18-2023, 01:09 PM   #96
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Interesting since Subaru of America has issued no such TSB...
Since this affects so many cars, and is a potential safety issue; binding steering, locked steering, etc. everyone that has experienced it should report it to the NHTSA:
https://www.nhtsa.gov/report-a-safety-problem#index
PS: The repair kit listed in the European Serice Bulletin shows in the U.S. parts system, it is orderable, but none are currently in stock in the U.S.
P/N: 34595CA000 MSRP: $29.42
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Trap63 (01-21-2023)
Old 01-21-2023, 04:38 PM   #97
Trap63
Trap63's Avatar
That's right, part available in Japan (not in Europe, here only on order submission), the total cost to Italy near Eur 32 plus custom fee and VAT (+25%),
In Europe no recall but only service bullettin.....maybe NHTSA will help us too...
Old 01-22-2023, 06:05 PM   #98
Lantanafrs2
Drives: 2013 frs red
Mine was replaced by a steering column expert. I don't think the bushing is anything special and may be used by Hyundai as well. Toyota parts guy told me my car didn't have eps then told me the eps wasn't serviceable. It's bad enough having a slow sports car but even worse having to deal with slow parts guys.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Opie (01-25-2023)
Is building a motor necessary for FI on this motor? Irace86.2.0 Forced Induction 44 02-27-2018 02:19 PM
Shifter Rattle and Replacement boredom.is.me Issues | Warranty | Recalls / TSB 19 04-27-2015 05:29 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED) Sportsguy83 Engine, Exhaust, Transmission 11 06-19-2014 12:29 AM
