Old 08-22-2013, 12:28 PM   #1
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Shifter Rattle and Replacement
It appears as though I'm having issues that others aren't. First is was the woodpeckers in my HPFP. Now there is a rattle from the shifter. The dealership said the shifter needs to be replaced.
Old 08-22-2013, 07:24 PM   #2
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
they replaced mine. Didn't help, plus they over-tightened my knob and now its upside down..whatever.
SloS14 is offline   Reply With Quote
Old 08-23-2013, 07:55 AM   #3
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
I just started to notice my Shift Knob would resonate between 4000 and 6000 rpm... Started thinking last night about resonant frequencies and whether or not a solid termination point would change it....
So I took it off, took it all apart filled the entire cavity inside (except for the threaded area) with "no more nails", let it completely harden, then put a bit in the top of it as well where the shift pattern piece goes, re-assembled it, re-installed it this morning and I hear nothing at all now from my shifter. It used to transmit a lot more from the linkage.
Once re-installed you cant even tell that the entire knob is now solid and filled. Will this solve the noise I was hearing long term, not sure yet, but I was shocked as hell this morning when it was silent and the shift knob felt better in my hand, not as flimsy.
Last edited by Migero86; 08-23-2013 at 07:56 AM. Reason: typo galore... need MOAR coffee now!
Migero86 is offline   Reply With Quote
Old 08-23-2013, 01:20 PM   #4
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by vteclol View Post
Perrin makes a reverse lockout lever that's advertised to stop the rattles.
For $100, lmao. How about a Kartboy short shifter to fix the rattle and actually make shifting more pleasant for another 100? Bigger benefit IMO.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 08-25-2013, 10:06 AM   #5
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
Had mine replaced. Now it's louder.
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 08-27-2013, 06:39 AM   #6
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
What's the specific symptom? Neither of my cars rattle...and I have a FR-S knob that I had on for a while, it didn't rattle either...
Admiral Ballsy is offline   Reply With Quote
Old 08-27-2013, 07:26 AM   #7
SloS14
SloS14's Avatar
above about 4k, the shifter vibrates and sounds sorta like a rattle-snake. Not really a spot-on impression but something along those lines. Angry robot rattle-snake?
Old 08-29-2013, 12:07 PM   #8
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
My shift knob was rattling, turned out to be the lower trim ring on the shifter knob. I popped it off, put a bit of electrical tape where the ring goes and put the ring back on. No more rattle.
sure74 is offline   Reply With Quote
Old 08-29-2013, 02:48 PM   #9
boredom.is.me
Custom User Title
I still haven't taken it in to the dealership. It was diagnosed in GA, but I'm in FL for school now. Would a short shift kit fix the issue?
Old 08-30-2013, 04:21 PM   #10
ugadogs_11
Drives: Whiteout FR-S
I work at a Toyota Dealership and have already had the Fuel Pump Replaced and now the Shifter Replaced. I just got the shifter done today, but I do know that the Fuel Pump is still chirping and we also had to put washers between my shift knob to straighten out. After these two TSBs, I have given up on the remedys to fix the concerns that the cars come in with.
ugadogs_11 is offline   Reply With Quote
Old 09-18-2013, 10:07 PM   #11
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
I'm also having some rattling sound coming from the shifter when reving between 4-6k rpm. [ame]http://youtu.be/pZUr4rVIulA[/ame]
Sent from my iPhone using Tapatalk - now Free
Sookainian is offline   Reply With Quote
Old 10-03-2013, 06:22 AM   #12
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Just had a Kartboy short shifter installed and now the rattling is worse. Need to take it apart again and find this rattle.
PS: Kartboy shifter must be the best upgrade EVER!!
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 10-03-2013, 08:55 PM   #13
SilentMike
Drives: 2013 FR-S 6MT Asphalt
I believe what we're hearing is the spring in the reverse lockout vibrating. I has a Kartboy and loved it, but the vibration sounded like radio static between 4k and 6k RPM, and drove me back to an OEM shifter that still rattles, but much less.
If Toyota/Subaru are smart, they'll ditch the whole reverse lockout gimmick in the future.
SilentMike is offline   Reply With Quote
Old 10-06-2013, 08:51 AM   #14
RevoG
RevoG's Avatar
Got to take a look at that. When we installed I also added a o-ring to the washer on the cross pin so there is no movement there. Just want one of my many rattles to leave the car.
Audible shifter rattle Hanzo Issues | Warranty | Recalls / TSB 134 08-17-2022 02:34 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Loud rattle, lots of shaking from shifter...not the knob...its the trans linkage continuecrushing Issues | Warranty | Recalls / TSB 8 05-18-2013 11:56 AM
Paddle shifter replacement? BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2013 06:41 PM
