#99 | |
Drives: 2022 MT Neptune GR86 Prem.
2) And as I also said, where this mod MAY (or MAY not) become significantly more valuable is when it is added to a tune and headers/exhaust that flow better than stock. Do you agree with both of these? If you do, then we are all
#100 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
| The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | OkieSnuffBox (07-20-2022) |
#101 |
“Removing restrictions from the intake tract is bad.” Some blue waffle guy.
#102 |
Drives: ‘13 AT FRS
What I have learned is, unless it is contributing to the PEAK hp/tq comprising of 1-2000rpm’s throughout the entire range. It is useless. So the dip does not matter. It didn’t in 2013 either.
How do I thank my own post? |
| The Following User Says Thank You to Ogt For This Useful Post: | Tokay444 (07-22-2022) |
#103 |
Not one person has said or even implied that.
#104 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
You God-tier Gen 2 don't even have tuning options yet, let alone as robust an aftermarket for headers. So I guess you might as well ride that coal filter high horse.
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | Ogt (07-20-2022), OkieSnuffBox (07-20-2022) |
#105 |
#106 |
Drives: ‘13 AT FRS
Thank you for your service
#107 |
Drives: '22 BRZ Limited 6MT - Ignition Red
Why are people arguing over a free mod that takes 1 minute? By removing an intake restriction, it can only help. Even if it's .1 horsepower to 5 or 10, it's free and takes one minute. No brainer IMHO.
Arguing over it is borderline insane. |
| The Following User Says Thank You to quikag For This Useful Post: | Tokay444 (07-22-2022) |
#108 |
Drives: ‘13 AT FRS
It appears the arguing stemmed from Tcoat&Co launching a campaign insulting everyone’s intelligence by doubting our ability to do very basic math. It now seems to have a direct link to those suffering from Firstgenitis..
#109 |
Drives: zd8 brz
if its not needed in California, the strictest state when it comes to smog laws(i confirmed its not needed, as it's not mentioned on any emissions label for the vehicle) then it's fine to remove
| The Following User Says Thank You to mycrors7 For This Useful Post: | joemysterio (07-20-2022) |
#110 | |
Also claiming something like a filter will net 10hp is quite substantial given it's well known a drop in filter rarely nets that much. Even if it's the newer FA24, it's not space kraut magic, it's still NA. So I find it hard to believe 10hp is possible. 4, mayhaps if you put in a drop in filter, but not the charcoal filter. Also, OP seems like the type to never want to accept they are wrong, so it's always fun to poke those type with a stick because that's what the internet does. Eventually they will make other pompous claims and no one will believe what they say. It's happened many a times. Still, very fun to read.
| The Following User Says Thank You to weederr33 For This Useful Post: | OkieSnuffBox (07-21-2022) |
#111 | |
If anybody bothered to actually read what I said instead of just getting all butthurt I very clearly stated that it would certainly help and I would just cut it out. All that I disputed from the start is the repeated statements that there is a 10HP gain to be had. The video doesn't even claim that beyond the deceiving title. A 10HP bump for a fraction of a second through one small space is not an overall gain. Now what it DOES (on that particular dyno at any rate) do is eliminate the hp dip at that point. In fact the the only reason it even hits 10 instead of the 4 and 5 across the rest of the band is because it is filling that 4 or 5HP drop. He bloody well speaks to it but that is ignored. I am beginning to seriously believe that the second gen cars attract a crowd that should be in BMWs since they have a superiority complex and take every statement as an insult.
| The Following User Says Thank You to Tcoat For This Useful Post: | weederr33 (07-20-2022) |
#112 | |
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | ROFL it's Waffle (07-21-2022), Tcoat (07-20-2022) |
| My First Run Impressions and Testing Results with (knockoff) Billet Power Blocks | Tatsu333 | Engine, Exhaust, Transmission | 9 | 09-16-2022 06:43 PM |
| ACE Header Independent Testing Results and Review - 199.6WHP on CA 91 Octane | CounterSpace Garage | Engine, Exhaust, Transmission | 847 | 08-26-2020 04:44 AM |
| Objective CLD (sound deadening) Testing Results | TOOSTUBBORN2FAIL | Electronics | Audio | NAV | Infotainment | 9 | 03-23-2016 06:41 PM |
| Motor Oil Testing Results | Rocket.BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 06-30-2014 10:48 PM |
| Air filter Testing | Fast_Freddy | Engine, Exhaust, Transmission | 0 | 06-06-2013 01:21 AM |
