Old 07-01-2022, 08:37 AM   #1
Mtl135i
Drives: BMW 135i
New wheels - colour choices and spacers
Just picked up a new set of wheels. Keep them gold or go silver ?
Also due to the size and offset and the PP front suspension I will need to run 8mm spacers up front. Should I run spacers on all 4 corners or just the fronts.
Thanks
Mtl135i is offline   Reply With Quote
Old 07-02-2022, 12:25 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Pink... with that color.
Old 07-02-2022, 12:59 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
fyi, that getcoloreffects.com site got blocked by my browser addon:
" Title: uBlock filters – Badware risks
! Description: For sites documented to put users at risk of installing adware/crapware etc.
! The purpose is to at least ensure a user is warned of the risks ahead."
i vote pink as well. or lime green.
silver is boring. silver is average. silver is typical. silver is a camry, it's the safe option. be a shining star of color.
Old 07-03-2022, 01:12 AM   #4
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Silver goes well with your paint color. If it was my car, I would choose silver, but I think it needs to be accompanied by a 1" drop.
Btw, how did you change the color of your wheels like that? I'd like to do the same to my own to help myself make decisions lol.
ItsReiko is offline   Reply With Quote
Old 07-03-2022, 03:56 AM   #5
Sam86
Drives: Toyota 86 GTS
Black would look cool
Check your wheels can run spacers, I had 2 sets of wheels that wouldn’t fit spacers under 20mm as the recess for the studs were further out than where they needed to be, and so the stud would hit and prevent the wheel being bolted on.
You should definitely run spacers on the rear, and a larger spacer at that as the wheel doesn’t poke out of the guard as much as the front
Sam86 is offline   Reply With Quote
Old 07-09-2022, 01:08 PM   #6
Racecomp Engineering
Silver, because I'm old. Nice wheels btw.
And yes spacers all around with appropriate studs.
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 07-11-2022, 05:23 AM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
For spacers, you can use a slip-on up to 3mm the way the car sits. Any slip-on spacer thicker than 3mm and under 10mm, you need extended wheel studs.
Spacers 10mm or thicker, you should get bolt-on spacers.
EndlessAzure is offline   Reply With Quote
Old 07-11-2022, 05:43 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I prefer silver, all though a bronze or gunmetal could work.. I like darker color wheels.
ARP extended wheel studs will give you room for slip on spacers. 2.5" is perfect for what you are after, I run 8mm spacers with plenty of threads.
You should be removing the rear hub to install studs but it's possible to install them without removing if you are willing to do some trimming, by cutting the nipple off at the end of the stud.
Old 07-14-2022, 07:32 PM   #9
SCFD
Run spacers all around with proper stud length. Either color looks okay but I'd probably just keep them gold if the wheels are already gold.
SCFD is offline   Reply With Quote
OEM STI wheels + Spacers spicyricecake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-14-2016 12:17 PM
Opinion on tire/wheels choices for tail of the dragon BobWhite Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-23-2016 07:30 AM
Do spacers fit OEM Wheels ? Wil Scion FR-S / Toyota 86 GT86 General Forum 3 09-19-2015 10:33 PM
Spacers on OEM wheels? BRZlimited BRZ First-Gen (2012+) — General Topics 13 04-11-2014 07:47 PM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
