Old 07-04-2022, 12:37 AM   #15
jflogerzi
jflogerzi's Avatar
What traction mode are you driving in? Sport or track mode?
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 07-04-2022, 12:38 AM   #16
andyk5
Drives: GR86
Get better pads
/thread
I want to, found csg spec pads. Issue is they are $400 for the front only and I am was worried that they might get destroyed as well.
andyk5 is offline   Reply With Quote
Old 07-04-2022, 12:41 AM   #17
andyk5
Drives: GR86
I started all days with everything turned on for the first 2 sessions. Then put it in “track” mode for the rest of the day.
Old 07-04-2022, 12:57 AM   #18
I don't know how the second gens are but first gens will heat the piss out of the rear brakes to keep the car pointed in the right direction.
There's little difference between threshold braking and ABS. It's a good goal to be skilled enough to ease right up against ABS without engaging it, but it's not the reason your pads are melting. You just need ones that can take the heat.
Old 07-04-2022, 02:11 PM   #19
racer01
Drives: 2022 86 premium manual
Stock pads are definitely the wrong pads for the job and suspect Powerstop are also too mild for the small stock brake system....overheating a pad compound typically causes very accelerated wear. Get proper race CSG pads as the easy button like C1 or C2.
I chose Ferrodo DS 1.11 F/R and have 75% left after 4 track days, 2 on a track that is brutal on brakes. 2022 GR86 with Falken RT660, camber and good brake fluid. I run with nannies off but found no need for trying the "pedal dance".
Used CSG C1 pads on my 2020 Supra after stock pads kept me from really being able to enjoy the car on my first track day. The CSG's are expensive but last a long time so it really works out at perf vs $$. I can all but guarantee you won't/can't burn through them in a weekend or two.
racer01 is offline   Reply With Quote
Old 07-04-2022, 02:43 PM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Pull the ABS fuse? Dunno if the car will drop power or do something stupid.
Old 07-04-2022, 03:30 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There are cheaper pads for track days. Carbotech xp10/gloc r10, ferodo ds1.11, and hawk dtc60 are common entry level track pads.
https://www.ft86club.com/forums/showthread.php?t=23680
Get all 4, the car isn’t super happy with staggered pads.
ineedyourdiddly
Old 07-04-2022, 06:57 PM   #22
CSG Mike
CSG Mike's Avatar
You need to do both front AND rear, or you'll overwork the fronts while the rears aren't contributing.
Good pads will save you frustration at the track; you've already burned up $400 in pads in your photos, and I can tell you'd have gotten more than 3 days out of a set of CSG pads.
CSG Mike is online now   Reply With Quote
Old 07-04-2022, 07:38 PM   #23
What's the pedal dance procedure for the second gen?
Old 07-04-2022, 07:52 PM   #24
CSG Mike
CSG Mike's Avatar
There isn't.
Old 07-04-2022, 09:20 PM   #25
There isn't.
How is VSC disabled for rollers? Strictly Techstream?
Old 07-04-2022, 09:47 PM   #26
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Turn traction control off. If you’re eating through pad at that rate, you’re probably driving well enough to turn that bs off.
Also, buy better pads, stock definitely won’t hold up. Serious track pads are expensive but will last a lot longer.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 07-04-2022, 10:13 PM   #27
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
This past weekend, there was a discussion in hpde class about braking. The instructor opined that is was better to apply the brakes harder for a short period rather than softer for a longer period. Keep in mind that this was mostly a novice class. I could get my FRS slowed for turn in at turn 1 at Summit Point starting about 350'. Other cars in my group would start braking even before 500' ft. If all other things were somewhat equal, who's pads would last longer?
Old 07-04-2022, 11:09 PM   #28
Tokay444
Anti stance.
Tokay444's Avatar
Can you street the CGS?
Tokay444 is online now   Reply With Quote
PMU NS400 front pads, StopTech Street rear pads, Motul RBF600 fluid Darth Vaden Brakes, Suspension, Chassis 1 06-17-2022 08:27 PM
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Safe oil temps for daily driving and spirited driving off the track? MilkyWitness Engine, Exhaust, Transmission 15 06-12-2019 08:21 AM
Interior Red Stitched Knee Pads Door Pads 2016 brz limited Rear View Mirror sokol Interior Parts (Incl. Lighting) 11 12-25-2018 09:37 PM
First time driving manual, some questions after one month of driving kyto31 Engine, Exhaust, Transmission 10 06-24-2018 10:57 AM
