Old 07-03-2022, 06:23 PM   #1
andyk5
Drives: GR86
Is it my driving or is it the pads?
GR86 800 miles , Buttonwillow raceway, Session 7 of the weekend, stock pads are toast. Threw in a set of powerstop track day pads PST-1539, 4 sessions later they are toast. Had an extra set of the same pads, threw those on and went to streets of willow and more than half the pads are gone.
I am not particularly fast, just middle of the pack driver.
So either I don’t know how to brake, or both stock and power stop pads are crap or this car has no brake ventilation.
Note: Brake temps were really hot, I had no probe with me but you could not get your face near the wheels without squinting your eyes due to heat coming off the rotors.
andyk5 is offline   Reply With Quote
Old 07-03-2022, 06:54 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
Are you on the ABS every braking zone?
Jdmjunkie is offline   Reply With Quote
Old 07-03-2022, 07:05 PM   #3
andyk5
Drives: GR86
Not every corner, at buttonwillow I am on the abs for turn 1, phill hill, sweeper and turn 13. So thats 4 out of 13 corners. The issue is phil hill, sweeper, turn 13 and turn 1 are back to back pretty much so I am thinking rotors can’t cool down.
Old 07-03-2022, 08:16 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Stay off ABS. Do the pedal dance.
Old 07-03-2022, 10:20 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by EAGLE5 View Post
Do the pedal dance.
Originally Posted by andyk5 View Post
GR86
Follow the build thread for my GR86!
Old 07-03-2022, 10:22 PM   #6
Originally Posted by timurrrr View Post
Does it not do it? There must be a different cheat code.
Old 07-03-2022, 10:32 PM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Nobody was able to find pedal dance or other "cheat codes" yet.
(to the best of my knowledge, and I spend an unhealthy amount of time following what's going on with gen2 cars )
Old 07-03-2022, 10:38 PM   #8
It's a diagnostic mode for safe operation on rollers. The mode can be engaged in Techstream as well as using the cheat codes. It's all described in the service manual. I guess the new one is yet to be scraped.
Old 07-03-2022, 10:43 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yeah, I know what pedal dance is. Forgot to clarify in the previous message that nobody found that for gen2 cars.
Old 07-03-2022, 10:52 PM   #10
We have all kinds of professionals on the site. I bet no one has bothered to ask for that page of the new manual.
Old 07-03-2022, 10:57 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Get better pads
/thread
ineedyourdiddly
Old 07-03-2022, 10:58 PM   #12
andyk5
Drives: GR86
Is triggering abs bad for the pads? Am I eating thru them because of that?
Old 07-03-2022, 11:54 PM   #13
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
ABS and Traction Control aren't necessarily bad for the pads, but the way they work (rapid brake pulses) puts a lot of heat into the pads which can speed up overheating. When pads overheat, they wear away very quickly.
Using "pedal dance" or doing a long press of the traction button turns off traction control, which can help. On the flip side, you won't have traction control assisting you on the course
EndlessAzure is offline   Reply With Quote
Old 07-04-2022, 12:31 AM   #14
andyk5
Drives: GR86
Wait, rlly..it kind of makes sense though.
Ok so ABS bad because increases heat, heat bad because destroys pads. Pedal dance is not available for these cars so I guess heavy braking without engaging abs is would be my goal.
Why is traction control bad? that had nothing to do with brakes? I thought it just takes power away from the rear wheels. Do you mean stability control? I think stability control engages the brakes to keep the car …well stable.
PMU NS400 front pads, StopTech Street rear pads, Motul RBF600 fluid Darth Vaden Brakes, Suspension, Chassis 1 06-17-2022 08:27 PM
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Safe oil temps for daily driving and spirited driving off the track? MilkyWitness Engine, Exhaust, Transmission 15 06-12-2019 08:21 AM
Interior Red Stitched Knee Pads Door Pads 2016 brz limited Rear View Mirror sokol Interior Parts (Incl. Lighting) 11 12-25-2018 09:37 PM
First time driving manual, some questions after one month of driving kyto31 Engine, Exhaust, Transmission 10 06-24-2018 10:57 AM
