Old 06-22-2022, 05:39 PM   #71
amirnew
Drives: 2013 BRZ sprintex SC
Someone can confirm that replacing the alternator fixed the issue for him?
amirnew is offline   Reply With Quote
Old 08-20-2022, 02:04 AM   #72
Powersfrs
Drives: Frs
Im having this issue on my new 2022 brz
Same as many have said…happens under trail braking…high load. Happens more now that I changed to stickier wider tires. Happens even more with a passenger.
Kw v3…stock sway bars. 265 18 35 azenis rt615k+ 2.3 degrees of camber. All around
Ridiculous!
Powersfrs is offline   Reply With Quote
Old 08-31-2022, 12:06 AM   #73
RedReplicant
Drives: None
No, it doesn't fix it.
I swapped motors and have an OEM Honda alternator on the car, it still drops out.
RedReplicant is offline   Reply With Quote
Old 08-31-2022, 08:15 AM   #74
ML
ML's Avatar
Drives: 13 White MT FR-S
get a smaller alt pulley and set the target voltage over 14v?
Old 08-31-2022, 03:03 PM   #75
RedReplicant
Drives: None
The alternator is already realistically overdriven as-is and it is running in high charge mode with the way KPower has it wired (3 wire vs 4 wire); I don't think it is a power supply issue.
I messaged with Icecreamtruk a few months ago who is LS swapped. He said he is only supplying the EPS unit with power and it doesn't cut out on him, but it requires shaking the wheel to wake up the EPS unit.
The wiring for the EPS takes in ground, 10a power, 80a power, can hi, can lo so I'm going to try depinning the can wires to test next event.
I will note that having dropped 110lb off the front of the car has lessened the frequency and intensity of the cutout, but it is still there.
edit: I checked my logs and 12v never drops below 12.7v.
Old 08-31-2022, 06:38 PM   #76
ML
ML's Avatar
I have mine wired up like that in “limp” mode so it only gets a 12v to turn on and then a high current line straight to the battery and mine still cuts out at high load. I just meant running the system at 14v instead of 12
The Following User Says Thank You to ML For This Useful Post:
RedReplicant (08-31-2022)
Old 08-31-2022, 07:14 PM   #77
RedReplicant
Drives: None
Well, that is unfortunate news. I know nothing in this area, but I assume battery voltage is the same voltage seen by everything 12v, right?
This data doesn't really mean much, but it seems that it is already seeing ~13.5v as-is and I don't see any huge drops that correlate with cornering, unfortunately.
Old 09-01-2022, 09:08 PM   #78
eb66
Drives: 2015 FRS
I have a 2015, and I installed a 2017 power steering motor and power steering computer. It worked fine, but still cut out. After that, I installed an emulator and disconnected it from the CAN wiring in the car. It no longer cuts out.
eb66 is offline   Reply With Quote
Old 09-01-2022, 09:33 PM   #79
RedReplicant
Drives: None
Any details on this emulator? Are you feeding it a constant speed to control assist?
Old 09-02-2022, 07:35 AM   #80
ML
ML's Avatar
Probably this:
https://www.agtengineering.com.au/pr...ering-emulator
RedReplicant (09-02-2022)
Old 09-06-2022, 04:36 PM   #81
RedReplicant
Drives: None
I messaged with them a bit and they said they haven't had any reports of cut out. I'm somewhat skeptical but maybe?
Old 09-07-2022, 12:10 AM   #82
Angrypuppy
Drives: 2022 BRZ Limited on order
Yay, happened to me today for the first time. Out at The Ridge in WA, turn 8.
For others that have experienced this, does it get worse or more frequent. Today was annoying. But I could live with it if this is all that I get.
Angrypuppy is offline   Reply With Quote
Old 09-07-2022, 12:17 AM   #83
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It doesn’t really get better/worse in my experience. Longer sessions make it worse.
Weird you have it at T8, I get it at 2,5 and 6.
Angrypuppy (09-07-2022)
Old 09-07-2022, 12:24 AM   #84
Angrypuppy
It happened one other spot, I can’t recall exactly where. I think 12. For sure not 2,5, or 6 though. Strange. 2-3 times in 8 and once somewhere else, probably 12. 5 20 minute sessions.
The Following User Says Thank You to Angrypuppy For This Useful Post:
NoHaveMSG (09-07-2022)
rattling when braking Latiii Issues | Warranty | Recalls / TSB 14 08-07-2014 12:16 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
Braking Issue In Mid Drift imravenit Tracking / Autocross / HPDE / Drifting 12 02-12-2013 03:16 AM
