Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 06-22-2022, 09:32 AM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Wrecky_Flowers_ View Post
Why wouldn't this work?
Probably not moving fast enough to create a noticeable effect.
Think about it, if they worked, they would be prevalent. Every hot boi track rat would have one. I can count, with no appendages, how many I have seen on any type of car that wasn’t a show car/hard parker.
Old 06-22-2022, 09:41 AM   #16
OkieSnuffBox
Drives: '23 BRZ Limited
Refer to post #3.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Ultramaroon (06-22-2022)
Old 06-22-2022, 09:46 AM   #17
jdmblood
jdmblood's Avatar
Drives: white subaru brz
You can get parts from Japan relatively affordably by going through a broker. I use Jesse Streeter for importing wheels and whatever else - here's a link to his site: https://jessestreeter.com/ordering-parts/. It's as simple as emailing him with the link to the part you want to buy (be it new or used on Yahoo Auctions Japan), and him returning your email with a quote to purchase and ship the part directly to you. Because the yen is so weak right now, it is an opportune time to be buying parts directly from Japan through a broker in lieu of going through a US-based retailer like Evasive.
ah got it. ive used streeter before to buy off of crooober
jdmblood is offline   Reply With Quote
Old 06-22-2022, 09:55 AM   #18
Originally Posted by Wally86 View Post
What the what?? Back story, please
Most of the really good parts have been deleted but still entertaining
https://www.ft86club.com/forums/showthread.php?t=40931
RToyo86 (06-22-2022)
Old 06-22-2022, 10:08 AM   #19
Ram air systems that are composed of a hood scoop, filter and sealed housing that immediately and directly force air into the manifold have been around forever and indeed do make a difference.
https://www.carthrottle.com/post/wha...-do-they-work/
But, "ram air" systems made up of long lengths of tubing with multiple bends and elbows that eventually get air to the manifold are really nothing more than very pretty cold air intakes. There is little to no ram effect on that air by the time it makes it all the way up and through all that plumbing and a filter.
Blighty (07-05-2022), OkieSnuffBox (06-22-2022)
Old 06-22-2022, 10:28 AM   #20
PulsarBeeerz
Drives: JRSC BRZ SOLD
$1650 at https://www.vividracing.com/-p-154965984.html
GruppeM is the same company that manufactures the Revolution Garage intake FWIW.
PulsarBeeerz is offline   Reply With Quote
Old 06-22-2022, 11:35 AM   #21
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I forgot about that thread. The gift that keeps on giving
The Following User Says Thank You to RToyo86 For This Useful Post:
Tcoat (06-22-2022)
Old 06-22-2022, 12:04 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is for a pro stock car.
“The amount of pressurization produced by a hood scoop varies as a function of the square of the speed of the vehicle. The formula for calculating pressure is:
0.0000176 x air speed in mph² = ram pressure increase in pounds per square inch (psi).
“If you plug in the numbers, you’ll find an increase in inlet air pressure of .142 psi at 90 miles-per-hour. Standard atmospheric pressure is 14.7 psi, so this represents an increase of just under 1 percent. If the air/fuel ratio is adjusted to compensate for the increased pressure, there should be a corresponding 1-percent increase in horsepower. For a 1,200-horsepower Pro Stock engine, that’s a gain of 12 horsepower. Hood scoop pressurization increases dramatically at faster speeds: It’s 2 percent at approximately 130 miles-per-hour, and 3 percent at 158 miles-per-hour. At the magical 200 mile-per-hour mark, the theoretical pressure increase is .704 psi, or 4.8 percent. That equals 56 “free” horsepower.
Old 06-22-2022, 12:29 PM   #23
I did say "make a difference" not "turns it into a jet fighter". If a direct to intake scoop does so little just how much do people think they are getting out of 4 foot long snorkels?
DylanJZA (06-25-2022), OkieSnuffBox (06-22-2022)
Old 06-22-2022, 12:50 PM   #24
Wrecky_Flowers_
Wrecky_Flowers_'s Avatar
Drives: '02 S2000; '22 GR86
Interesting take.
It's probably not as functional as a custom long-tube cold air intake, but (believe it or not) life isn't all about horsepower gains. Some people just want to buy really nice, high-quality parts for their car, regardless of whether their impact is marginal. I'm sure this offers an improvement over the stock system (their S2000 intake was one of the better off-the-shelf options in terms of performance), and it's a really nice part.
In terms of prevalence, the cost rules out seeing these in every other BRZ/GR86 track car over something less expensive with higher performance. It seems like common sense that, in general, 99.9% of people who buy a $30k car are not in the market for a cold air intake that costs close to 6% of what they paid for their cars. It's even less likely that the people you are referring to (hot boi track rats?) would spend $1700-ish on a moderately-effective intake over, say tires and brake pads. Again, this is just common sense, but I understand that some people need help connecting the dots.
If someone has the disposable income to be able to justify buying one of these, I wouldn't blame them for doing so. Just because you are unable to do so does not make this a bad or ineffective part.
Wrecky_Flowers_ is offline   Reply With Quote
The Following User Says Thank You to Wrecky_Flowers_ For This Useful Post:
jongers (06-22-2022)
Old 06-22-2022, 12:54 PM   #25
Wrecky_Flowers_
Originally Posted by OkieSnuffBox View Post
Yep, no data = bling.
There have been tests done before on other vehicles, there is a very, very slight ram air effect on intakes like this, but it's not until well above "Do not pass go. Go directly to jail" speeds.
And even then we are talking tenths of a %.
If the intake makes +1 whp more than stock, would you still call it ineffective?
Old 06-22-2022, 01:00 PM   #26
I would call it a horrible return on investment for the price.
You can get more than 1whp by only driving your car on low humidity days!
Old 06-22-2022, 01:01 PM   #27
OkieSnuffBox
On a car that seems to be making between 210-220whp from the factory, 1whp would be tenths of 1%, like I previously said. And that 1whp comes at like 125 mph, so it's not really relevant, is it?
And in that case (1whp) I would call it "statistical noise."
The Following 3 Users Say Thank You to OkieSnuffBox For This Useful Post:
DylanJZA (06-25-2022), Tcoat (06-22-2022), Ultramaroon (06-22-2022)
Old 06-22-2022, 01:03 PM   #28
Interesting take.
No the fact that it is an ineffective part makes it an ineffective part!
Don't give a flying fuck on how people spend their money but let's not pretend it actually gives you anything even measurable in performance.
Posers will pose!
OkieSnuffBox (06-22-2022), Ultramaroon (06-22-2022)
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Revolution x GruppeM Intake TwinRz Engine, Exhaust, Transmission 15 07-31-2014 07:34 PM
aFe Dry intake system FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 1 08-15-2013 03:13 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
FS: afe DRY intake system Laika Engine, Exhaust, Bolt-Ons 2 02-28-2013 10:37 AM
