Old 05-23-2022, 09:23 AM   #1
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
Front lower ball joint nut removal tips?
For a 2017 with 50K miles, the ball joint nuts sure are giving me problems. In no particular order: I've soaked them overnight in BP blaster, used a wrench, used an impact gun, beat at them with a hammer, cut away the boot and cleaned the grease and gripped the ball joint shaft with vice grips, straight wailed away on the control arm with a sledge, and even (unsuccessfully) tried to use a pry bar to pull off the caps underside the ball joints on the bottom of the control arms: nothing I seem to do will get the ball joint nut to break free. The bolt just spins endlessly with the nut. Subaru's design is giving me fits.
Is there a secret? This is driving me mad, I spent at least two hours on a single side trying to get it off. My next step is to cut the nut off with a dremel with a metal cutting disk, but I'd rather avoid that just due to the tight nature of the space.
I don't care about the condition of the ball joint, ball joint nut, or LCAs after I'm done. It's all getting replaced.
series.trackday is offline   Reply With Quote
Old 05-23-2022, 09:52 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why not rent the tool from a place close by? The right tool makes it far easier
Old 05-23-2022, 11:27 AM   #3
series.trackday
I don't know what you mean by "the tool", but I've got a pickle fork. My problem isn't pulling the ball joint, it's the ball joint nut, which is to say, the nut holding the ball joint in the LCA, to the upright.
The Following User Says Thank You to series.trackday For This Useful Post:
DarkPira7e (05-23-2022)
Old 05-23-2022, 11:36 AM   #4
Ohio Enthusiast
Drives: 2018 BRZ
Yeah, the service manual just tells you "Remove the cotter pin and nut.". To actually remove the ball joint from the knuckle it tells you to use the puller, but a pickle fork should work just as well (especially if you don't care about reusing it).
No idea how to remove the nut in your case, though. Perhaps a nut splitter would be easier to use than a Dremel with a cutoff wheel?
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
series.trackday (05-23-2022)
Old 05-23-2022, 12:08 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You are too far gone now. Likely need to use a nut splitter.
When I get one that is stubborn I’ll take a pickle fork and tap it between the knuckle and the control arm to put tension on the ball joint. Then hit the nut with impact. Doesn’t work every time.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Ohio Enthusiast (05-23-2022), series.trackday (05-23-2022)
Old 05-23-2022, 02:24 PM   #6
series.trackday
That's what I feared. I guess I'm picking up a nut splitter on the way home from work today.
Why can't they have sensible ball joint design? What's wrong with a keyed shaft? I'm replacing the entire assembly with SPL Parts' FLCA, which has a heim joint with a through-stud in place of the ball joint. No more of this mess.
Thanks to y'all for weighing in.
Old 05-23-2022, 03:13 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Tried a torch at all? I don't see it mentioned so I thought I'd ask.
Joon525 is offline   Reply With Quote
Old 05-23-2022, 03:16 PM   #8
series.trackday
No, I haven't got a torch. A nut splitter's cheaper than a torch, so...
Old 05-23-2022, 04:28 PM   #9
DarkPira7e
DarkPira7e's Avatar
Ahh ok, that sucks then. Make sure you've got something to heat it up or use a nut splitter
Old 05-30-2022, 06:25 AM   #10
series.trackday
The nut splitter didn't work due to the ball joint nut having a flange and being recessed into the knuckle. I ended up having to go with the Dremel with metal cut-off wheel.
I cut down the midpoint of the shaft until I got to the nut, cut off one half of the shaft, rotated the nut/shaft with vice grips 180 degrees, cut off the remaining half of the shaft, an then cut down the center of the shaft/nut combo. Finally popped off one side of the nut and then was able to rotate what remained of the nut separately from the ball joint.
That was a lotta work. This is the first time I have cause to say, "If I ever met the engineer that designed this I'd give them a good choke."
Who the hell comes up with an integral ball joint without a keyed shaft or something?
The Following 2 Users Say Thank You to series.trackday For This Useful Post:
bcj (05-30-2022), Ohio Enthusiast (05-30-2022)
Old 05-30-2022, 06:56 AM   #11
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Glad you finally got it off, pal. After spending some time wrenching on this car, I found myself thinking the exact same thing at least few times.
TheBoss77 is offline   Reply With Quote
Old 05-30-2022, 11:51 AM   #12
Icecreamtruk
Drives: Track preped NA FRS
Gotta say, at that point, why not melt it? Cant be tight if its liquid
Icecreamtruk is offline   Reply With Quote
Old 05-30-2022, 12:00 PM   #13
series.trackday
Well, first off 'cause I already did it, second, I don't have a torch, third, I'm still using the knuckles, and if I actually torched the nuts hot enough to get the steel malleable it would affect the integrity of the knuckle and possibly the hub.
Old 06-01-2022, 10:18 AM   #14
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
over a week too late here, but you should have been pushing on the ball joint, not pulling on it.
Every ball joint Mfr for the last 90 years or so has used a tapered fitting and I've rarely had issues getting the nuts loose. Modern Japanese cars use torque on the nut to put some tension on the threads and keep the nut from loosening. Murican cars (and earlier Japanese) use a castle nut and cotter pin at much lower torque. I've never had any of them come loose on me when properly installed.
That said, how to get these things loose is to jack up the car from the bottom of the ball joint. you put the ball joint in compression with a bunch of weight on it and that keeps it from spinning. then zap the nut with a good strong impact wrench and it'll pop right off.
shoving a pickle fork under there and prying the ball joint down only made the problem worse because it was pulling the tapered pin out of the joint putting all of the pressure on the threads of the nut and not keeping the pin jammed in place so it won't spin.
once the nut is loose, then and only then should you wail on the knuckle or use the pickle fork to release the pin.
After the fact, but HTH someone else.
Matt93SE is offline   Reply With Quote
Front end noise- not bearings or ball-joint... in_sherman Issues | Warranty | Recalls / TSB 6 07-19-2020 01:24 AM
ball joint leak msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-01-2019 11:17 AM
Front lower control arms, buddy club ball joints, RLCA devildriver.ab Brakes, Suspension, Chassis 4 09-13-2018 10:52 PM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 05:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
