Old 05-13-2022, 05:45 PM   #15
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by NARFALICIOUS View Post
I'm sure running the secret offset instead of the +35 will be the tenths-of-a-second difference maker for all of you pro racers who scoop them up.
You do realize that +35 in the rear simply doesn't fit with 245/255 tires on gen2 cars?
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
bradsm87 (05-14-2022)
Old 05-13-2022, 06:27 PM   #16
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Any 17x9.5 size?
botbs is offline   Reply With Quote
Old 05-13-2022, 09:37 PM   #17
bradsm87
Drives: It has 4 wheels
Originally Posted by 10secdream View Post
I don't think there is a magic offset that offers clearance in the rear and the front at the same time. You space the front or trim the rear or have different offsets front to back. This is assuming you are running a reasonable width tire (245/255).
^^^ This ^^^
bradsm87 is offline   Reply With Quote
Old 05-18-2022, 11:59 AM   #18
10secdream
Drives: 2022 Toyota GR86
Word on the street is the size is 17x9 +46
10secdream is offline   Reply With Quote
Old 05-18-2022, 02:53 PM   #19
___LUNK
Drives: Laguna Seca Blue GR86
Interested in a set if they see a wider release, not into having hard to replace wheels for track use.
___LUNK is offline   Reply With Quote
The Following User Says Thank You to ___LUNK For This Useful Post:
timurrrr (05-18-2022)
Old 05-18-2022, 05:13 PM   #20
OkieSnuffBox
Drives: '23 BRZ Limited
Probably considering the offset of the new TS-5 Titan to be released.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 05-18-2022, 06:03 PM   #21
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Wouldn't a higher positive offset make the wheel/tire closer to the spring? And as the gen1, 17x9 +35 245 are the closest you can get on stock suspension?
And I realize if it doesn't fit,it doesn't fit. But no need to act like it's a secret and only the special few (10? LMAO) that order it will have the advantage at the track.
Originally Posted by mike2100 View Post
If it's the perfect offset I'm sure they'll go into normal production.
This was really my point, it'll be common knowledge at some point.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 05-18-2022, 07:18 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Higher numerical offset (e.g. +45) = tucked in
Lower numerical offset (e.g. +35) = more poke
"Offset" is the dumbest spec/name ever, but it is what it is.
I like that the Owner's Manual calls it inset (which makes a lot more sense), "also known as offset", or something like that.
If fitment / geometry of the fender wasn't an issue, +35 would be better than +45 (or anything numerically higher than +35) on track due to larger track width. Larger track width = more grip.
The advantage here is not really directly in performance, but in the ability to fit the same desired 245 or 255 wide tire with less effort (e.g. RLCAs vs RUCAs vs "no way it will fit").
You can't go fast in a car that can't go
I agree it's "stupid" that the offset is not openly specified yet, but that's also what many other wheel companies that I contacted are doing.
I 100% expect WedsSports to eventually turn it into a "regular" model, given that gen2's are going to be very popular in Japan, and elsewhere.
Perhaps they just want to start with a limited run to see what real customers do with those wheels (e.g. end up running spacers anyways, or want even higher inset, like I might need to do with the wheels I'm waiting for) before starting large scale production for a final spec.
Old 05-18-2022, 09:17 PM   #23
NARFALICIOUS
Thanks for the explanation, I'm pretty familiar with offset. And I have +35 TC105Ns so that's why I'm here.
I guess I was just confused why +35 on 2nd gen wouldn't fit, but I guess you're saying it's Not the spacing to the strut, but because of the rear fender clearance on 2nd gen?
Anyways, mine are 245. I'll probably test fit them on a 2nd gen when/if I get one, but I'm sure this will all be solved by then and I'll just be late to the party.
I don't like running spacers
NARFALICIOUS
Noob Poster
1988 | 2016
Old 05-18-2022, 09:25 PM   #24
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Oh wait you haven't seen this thread?
NARFALICIOUS (05-18-2022)
Old 05-18-2022, 10:27 PM   #25
bradsm87
Not too bad for the rear. The fronts will need spacers. It's a shame wheel manufacturers don't offer two different offsets to resolve this. In Australia, wheel spacers are illegal so people need to drive illegal cars around in order to get good fitment.
Old 05-18-2022, 10:58 PM   #26
PulsarBeeerz
Drives: JRSC BRZ SOLD
Huh? They are offering two different offsets. 35+ and 4x+. A lot of wheel manufacturers offer multiple offsets for a given wheel design.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
timurrrr (05-23-2022)
Old 05-18-2022, 11:19 PM   #27
bradsm87
Ah yes I can see they already offer +35. That's good. It'd be a bit odd having the deep taper "MR" face on the front and the flat "F" face on the rear but it's something. Personally I think 11mm offset difference between front and rear is too much but I guess it's better than nothing.
Apec EC-7R, ARC-8 and Enkei RPF1 are the only ones in 17x9 5x100 in offsets suitable for the 86/BRZ that I know of.
Old 05-19-2022, 09:46 AM   #28
OkieSnuffBox
The new Titan TS-5, is 18x9 ET47. They are available for preorder with an expected delivery date in August.
WEDS TC105X 17x9.0+35 special color batch, ETA November, Circuit Black and TS Bronze Gruppe-s Wheels and Tires 125 11-23-2022 05:18 AM
Rare - Circuit Black Wedsport TC105X 17x9.0 SoCal - Pick Up Only ericdavidchen Wheels and Tires 0 01-09-2022 08:54 PM
SOLD WedsSport TC105X 17x9+35 EJTI 5x100 with 255/40 Hankook Tires and more hifiguy99 Wheels and Tires 10 03-05-2021 10:49 PM
WEDS TC105x 17x9.0+35 2018 EXCLUSIVE Gunmetal color, Japan made, rare & lightweight Gruppe-s Wheels and Tires 52 07-29-2020 12:55 AM
WedsSport TC105X 17x9 +35 and TRD Springs JeffFAFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-10-2020 08:46 AM
